- Nov 29, 2010
- 619
I've been having a weird loss of power/miss on my 1969 351W(4barrel intake and carb, headers, pertronix, all else stock) for the last few weeks, which almost always occurs on the same section of road(it's not the road). While driving, just as the thermostat is opening up, I get a miss, which doesn't seem like a cylinder, but all. The tach will drop about 200 rpms, and then continues running. It only seems to happen when I'm cruising, not on, or off the gas. I'm usually at 3,000 rpms at this point, but, it's only when I'm steady on rpms. After a minute or two, it goes away. I've adjusted accelerator pump, and air/fuel mixture (I've adjusted with vacuum gauge). I really think it's running lean, but, not sure. I don't think it's Pertronix, or plugs/wires, since it's dropping power all together. The carb is Edelbrock 1405. The motor runs great, and starts right up, all the time. It's definitely not backfiring, just seems like power cuts of instantaneously, and comes right back.
