I have tubs of parts, I am looking to get rid of them all together. Make me a reasonable offer on all the parts, here is a quick listing below.
Quantity Description
4 Side marker light bezels
3 Tail light trims (3 pair)
4 Turn signal assembly
3 Turn signal lens
1 Tail Light Lens - right
2 Tail Light Lens housing - right
1 Tail Light Lens housing - left
5 Gas pedal assembly
2 Window crank handle (knob and crank)
3 Door handles
2 Wiper arms
4 Wiper arms
1 Door lock
7 Handle cup
1 Tail gate handle backing plate
1 Tail gate handle
1 Tail gate handle nut and bolt
1 Door latch
3 Mirror - aftermarket
2 Heat Switch cable
2 Heat Switch cable bezel
3 Temperature cables
3 Defrost cable
1 Choke cable
2 Brake light switch
1 Dash control light
1 Lift gate handle
1 Column covers (4 bottoms and 2 top)
1 Seat hinge covers
1 Interior handle (left hand)
Misc bolts
3 Headlight ring - chrome
4 Headlight ring - painted
3 Headlight cups
5 Headlight trim ring
1 Shifter cover
1 4x4 shift knob
1 Ashtray
1 gas cap
1 Tailgate reflector
4 Chrome bumper trim
1 Reflector trim ring
1 oval trim ring
1 Pulley
4 Wiring harnesses
2 U joints
1 Cold air cowl/heater box hose
1 Passenger door latch
1 Brackets
3 Autolite 45 sparkplug
1 2 Barrel carbureator
1 Electric windshield wiper motor
1 Lightbulb /harness
1 Relay
1 Flasher
2 Hood Latch
1 Trim
1 Jack hold down bracklet
1 4x4 shiftboot
3 Shift boots
4 Crank pulley
2 Water pump pulleys
5 Tail gate latch
3 Hood latch mini
2 Tailgate cups
3 Hood springs
1 Battery hold down
1 Holley electric fuel pump hold down
Bolts
1 Blower motor with fan
1 4x4 shifter assembly
Radiator parts
2 Leaf busing bracket
3 Turn signal lens
3 Door handles
2 Wiper arms
4 Wiper arms
1 Door lock
7 Handle cup
1 Tail gate handle
1 Door latch
2 Heat Switch cable
3 Defrost cable
1 Choke cable
1 Lift gate handle
1 Seat hinge covers
Misc bolts
3 Headlight cups
1 Shifter cover
1 4x4 shift knob
1 Ashtray
1 gas cap
1 oval trim ring
1 Pulley
4 Wiring harnesses
2 U joints
1 Brackets
1 Relay
1 Flasher
2 Hood Latch
1 Trim
1 4x4 shiftboot
3 Shift boots
4 Crank pulley
5 Tail gate latch
3 Hood latch mini
2 Tailgate cups
3 Hood springs
1 Battery hold down
Bolts
Radiator parts
