Low Fuel Pressure Problem....suggestions?
zion2004
Hello,
I'm new to the group....so i thought i'd tap into the wealth of knowledge
out there! I have a 73 bronco that's trying to drive me crazy with a irritating
fuel pressure problem. I have a 302 that's a nice mildly built motor with
edelbrock cam, intake, carb, ceramic headers, duraspark/HEI ignition...it has
about 4K miles since the complete rebuild. Here's the problem....i noticed that it was hard to start after it had been warmed up and driven...looking
under the hood one day after starting it up and letting it run i noticed that
the fuel pressure was slowly dropping to eventually not registering on my
in line gage. Backing up a step i have the main fuel line going into a fram
cartridge style filter, from there it goes to a stock ford mechanical pump,
from the pump i have a hard line to the carburetor with a small line filter
and a nice liquid filled gage. So the first thing i did was change the big fram
filter and then the line filter....the cartridge filter showed no dirt..i had the
tanks flused during the rebuild. I then decided to check the gage...with a
new one....no diffrence. So then i thought the pump is defective...replaced it
with a new one from napa....slightly more pressure initally...but still drops to
o after running. Then i started tracing back the main fuel line...replacing anything that was rubber with new hose....same result. The engine runs very
consistently at temperature wise.....people have said vapor lock?? while i was tracing the line...it was never very close the exhaust?? I've run it without the gas caps on....same. Does anyone have any ideas for me?
This thing is killing me..........thanks in advance
broncobillyusmm
Mountain Home
What kind of fuel pump are you running? If your running a holley red pump it may be putting too much pressure on the needle and seat and causing fuel to seep by or causing vaporlock. It is also important to have a very "free-flowing" type filter before the pump such as a fine screen. If a finer filter is used it causes the pump to have to work hard to pull that fuel out of the tank. The discharge side of the pump should have the finer filter. I use a holley pressure-regulating return valve on my rig. This allows me to control the inlet pressure to the carb and also prevents vapor lock by constantly circulating fuel through the lines.
In reality if the truck is at idle the pressure should actually increase. Hope this helped.
... it goes to a stock ford mechanical pump
He said it has a stock pump, and that it was replaced with no change.
IT does have all the classic vapor lock symptoms. Are either of the fuel filters transparent? Can you see bubbles (air or boiling fuel both look the same)?
Once fuel is pressureized then vapor lock is greatly reduced. Vapor lock is the pumps inability to pull boiling fuel. Air leak into the suction side of the fuel line causes the same problem, just not temperture related.
I am fairly stumped. You say it has 4000 miles on it. Does it stay running if you keep moving? Your description sounds like it is a problem with extended idle times, but I want to confirm that before I jump in that direction.
airman
It does sound like vapor lock. If you have an aluminum intake that can radiate a bunch of heat. I had a similar problem. I fixed mine by changing to an electric pump, changing my fuel lines from the frame to the carb with an fittings and aeroquip hose. I also put spark plug wire insulating sleaves on my fuel lines and an insulating spacer between my carb and intake. Then I put the louvers in the hood and drilled holes in the side of my scoop, and cut awa y most of one inner fender. I kept making changes (not in that order) until I did not have the issue any more and thats where I stopped.
I had the most noticeable results from the carb spacer and the electric pump but it never really went away until I did all of that.
I have a 351W and you have a 302. I bet you have less trouble than me in venting heat from you engine bay. I would try the carb spacer (edelbrock has one of thick paper material about 1/2" thick that does pretty good), then the line insulator, then the fuel lines, then the pump.
72Sport
I would look at the sending unit and make sure the sock/filter is on the pickup tube. There might be enough "stuff" left in the tank to block the end of steel tube and shut off the fuel supply after it runs awhile.
blubuckaroo
Grease Monkey
Ridgefield WA
What range of pressure gage are you using? If you are using a gage with too high a range it might not register the 4 lbs or less needed by the carb. I think your problem with starting might be heat soak. Modern gas has a lower boiling point than the old stuff and the fuel in the carb can boil over into the intake after you shut it down. My Edelbrock did that even with a heat spacer until Edelbrock advised me to lower the float level 1/8". That gave it enough room to boil without dumping into the engine.
Z
zion2004
Everyone,
wow...thanks for all the great real world advice and experiences....given the
scenario i described....should i try to take some variables out of the equation
like running a remporary line to a gas can? or removing the filter from my fram
cartridge filter? I do have a aluminum intake...the idea of a carb spacer and
insulting lines sounds good...i'm afraid i would'nt have hood clearance though..
One thing i did'nt do...the fuel line that came on this truck that runs the length of the frame is a hard plastic type with 3/8 rubber connections going to the manual switching valve, fuel tank, and the cartridge filter...i replaced
all the rubber and used new clamps....i did not replace this hard plastic line
thoughts? My pump is just a stock napa pump...and the gage registers 4.5 or
6 pounds initally. One thing i thought of was i have a aluminum bracket i made coming off of a manifold bolt that "collars" the hard line near the gage
and filter assembly to keep it from shaking...maybe it's transmitting heat to
the line? Last question...when i got the truck it had no gas caps....so during the rebuild i just got ones from advance auto...they don't say vented...is there a easy way to tell? are they no good? Thanks again for all the help
i really appreciate it.
Steve T.
scsm76
Shaver Lake, CA
It sounds like the engine runs fine under all conditions and the only problem is starting a warm engine, correct?
Regardless of fuel pressure the float bowls should still be full of fuel when you go to restart, if the bowl is full it should start with no fuel being pumped. Your hard warm starts may be unrelated to your pressure gauge readings.
Z
zion2004
Low fuel Pressure Revisited..........
All,
thanks for all the responses....alot of good ideas out there as i expected.
I had time to mess with it a little bit today..here's what i did. someone
suggested that i may have a problem pulling fuel through the fram cartridge
filter....so i removed the filter assembly from the canister. Another suggestion
was isolating the hard line....I mentioned i had a aluminum bracket holding the
line near the gage that was mounted off of a manifold bolt...so i removed that
clamp. It was about 45 degrees here in Pittsburgh today....but it fired right up as usual....I checked the fuel pressure gage 5psi, and noted the time.
As the engine warmed to operating temperature....i only have the original
bronco temp gage...it read 190....the fuel pressure began to drop...4psi
i shut the truck off...waited a minute and it started right back up....ran it
for awhile....dropped again, and again finally the gage read "0"...the truck
never dies while idling or driving. The time frame to get to o pressure from
cold start up was about 25 minutes. I shut it down waited a few minutes and tried a re-start....it took awhile before it would start up....i'm confused!
a guy wrote in saying that the fuel bowls should be full if it did'nt die...so it should re-start? During this last test...i kept feeling the hard line and the carburetor itself....there was'nt anywhere that was unpleasent to keep my
hands on??? So here again is what i tried: new filters, checked gage, new rubber lines whereever they connected tothe hard plastic original line, checked or replaced all clamps, 2 new mechanical fuel pumps, isolated the
hard line, removed the cartridge filter.....lastly this engine runs great...once it's started.....i noticed a off idle bog or hestitation a few times...but i associated that with the non existent fuel pressure??? Any more ideas or should i move to the "for sale" part of this web site! Thanks in advance you
guys have great experience...............
Steve T.:-[
OK, I'll run with one of your ideas. If you pull the rubber hose off the pump and put it in a gas can, how long will it run?
Also, if you drive it will it keep running or does it die on the side of the road? (not using the gas can). I am trying to figure out how it got the 4,000 miles on it.
We know you have a fuel delivery issue, the gauge and symptoms tell us that, worry about the bog after you get the fuel delivery right.
