351YJ
We were going to attempt to set the timing on the motor I just rebuilt. However, the oil pressure seems really low. We had the motor running at 1100-1200 rpms, but the psi was only 10-15. If we goosed the carb up to 2000rpm's it would only go up to 25psi. It doesn't go any higher than that. I'm not sure what's going on. Last weekend when we started it for the first time it was at 40psi, and it hasn't been there ever since. I replaced the oil pump today, but haven't had a chance to check it out yet, b/c I ran out of time. So it will have to wait til next weekend when I can get the pump primer. The pump I replaced was a Sealed Power pump. The "new" one is a Melling pump. I have a Melling pickup tube on it as well. I believe they are standard volume pumps. The oil pump driveshaft was new when I put the first pump in.
A mechanic-friend said it "could" be the main bearings, but we would hear the crank "slapping" around. We didn't hear anything like it.
I'm running a mechanical Autometer gauge. We also tried another gauge on it to see if that was the problem, but it gave us the same reading.
Specs: '79 351W, hydraulic cam/lifters, D00E heads, flat top pistons, Melling oil pump.
I'm really lost here, and need some help from you expert Ford guys.
