low oil pressure
ca1a73
I know i beat this to death in the past. But could anything else cause low oil pressure other than bearings or bad reading from guage?
Steve
Grand Junction, CO
There's a bypass valve inside the oil pump. If that sticks open it would cause low oil pressure. Low oil level. Low viscosity oil.
Does it change at all, or is it always the same with hot and cold engine and at different RPMs?
C
ca1a73
It changes with the viscosity. its fine for about a 1/2hr, then slowly drops. I get about 20-25 on highway, and almost 0 after stopping. I changed the oil pump, with no improvement.
broncnaz
That pretty much points to bad bearings mains, rods, and cam once your oil heats up the viscosity goes down a little thats why you get better oil pressure when its cold.
C
ca1a73
Thats what i figured. Can i just mic them, and put new ones in without pulling the motor? I have a 3.5" lift
Steve
Grand Junction, CO
It's a PITA, but yes, you can put new bearings in without pulling the motor. Not fun doing it from underneath tho. Personally, I'd say it's much easier to just pull the motor, put it on a stand, and do them that way. (Of course, I have an engine hoist and engine stand in the garage...)
CRUZIN66
SAN DIEGO
what oil are you running? if you can, go with straight 30w. i had an older engine with a ton of miles on it. the oil press would drop down to 5 after getting off the freeway. i went to straight 30w and it fixed the problem. it might be worth a shot before you rebuild your engine.
74bronc
Like was mentioned you can change the lower end bearings with engine in the truck, but you can't change cam bearings in the truck. If the rod/main bearings are worn, then most likely the cam bearings are worn. If you had the means, you could pull the motor out and do a quickie rebuild that will get you by for a few hundred bucks(rings, bearings, gaskets).
Steve
Grand Junction, CO
While that may increase the oil pressure for a little while, it doesn't fix the problem, it just hides the symptoms for a while longer.
C
ca1a73
I am running 20w 50 and STP oil treatment. Thsats pretty thick stuff , no?I know i have to pull the engine, just putting it off, Spring is around the corner, and im out of money....spent too much already on it.
michael welch
kent, washington
If you have the stock electic gauge, then it could be your sending unit. They get a pin hole in the diapham that's inside and when the oil is cold it's thicker and will show oil presure and when it warms up it thins and oil presure goes away.
