Eoth
- Mar 10, 2004
- 1,680
Ok..... Swapping in an explorer 5.0 but staying with carb. Specs say that a Holley TA should have 5-7 PSI. HOWEVER looking at all the electric fuel pumps, the selection is extremely limited for a pump in that exact range (which blows my mind). That means that I will have to regulate it down. Am I nuts for not wanting to use a regulator (always trying to keep it as simple as possible). If I am going to regulate it down why would I even care if it is high or low pressure (no real difference between turning it down 2PSI or 20PSI).
What am I missing? Any recommendations (part numbers would be helpful) for a decent pump that doesn't require a regulator?
