- Nov 1, 2001
- 3,349
Putting on lower quarters, and confused as to the stack up. The lower quarter welds to the tail corner, but there is a third layer from the corner post that only had a spot weld where it all met the rear floor cross brace. From there up was not attached, and looking at other bodies, it may have only had some sealer between it and the lower quarter. Why would they have a panel just hanging out?
Now it is seeming like the best way to install will be to weld the corner to the lower, then set it all in place and finish up since you can't really get into the light opening to do much.
