Lower steering shaft from BCB
Chief Master Sergeant
Retired U.S. Air Force
I'm using the 4x4x2 box and the upper shaft from 74, with the rag joint removed. BCB sells three different lengths. Anyone else have a similar setup that might know what length I will need?
Are they installed yet, where you can get a basic measurement? Or are you trying to get your ducks in a row before installation?
You probably saw where he recommends the 14" one for a stock column, but it doesn't say what, if any, differences the boxes might make.
You going with double-ended splines, or a collapsible?
I'm just getting everything ready. The box is in and the column should be in today. Was planning to just use the solid lower shaft with two splines joints.
ET
Dallas, TX
I have BCB's lower shaft kit. It's been awhile but I really thought the shaft length Chuck gave me was 12" but it was definitely the shortest shaft they had back in 99 or 2k. This is with cut down stock straight shaft, borg ujoints, middle shaft and 75 bronco ps gearbox. Stock body lift.
edit: to add. I installed the top joint about 2 inches below the lower steering column.
Eugene
