Lower track bar bushing question
muskrat
'Morning.
Got a set of new track bar bushings from WH. Went with the poly's.
The bottom bushing would not go on the axle mount with the metal sleeve in the bushing. It was tight even without the metal sleeve.
My question is, are you supposed to use the metal sleeve on the mount, or is the sleeve just to hold the two halves of the bushing together while you install it in track bar?
Help please.
WILDHORSES
USA
You should use the metal sleeve with the new bushings. Make sure the old sleeve is off the lower bolt. All the lower sleeves are the same size 66-77 even 78-79. That's all I can think of unless a PO did something unusual, but we know that never happens.;D
bknbronco
North Metro, MN
There should be two different size bushings and sleeves. One for the frame side and one for the axle side. Maybe you got em mixed up?
muskrat
muskrat
I got the right ones where they should be. The lower bushings sleeve would only slide over the threaded part of the "stud" for lack of better term. No way it was sliding over the rest. The bottom bushings that I removed didn't have the metal sleeve either. Unless the sleeve was rusted on to the shaft and I didn't know it?
bknbronco
North Metro, MN
If the bushings were tight on the shaft then run it! Im not sure the purpose of the sleeve anyhow...except to keep you from overtightening.
