Lower Windshield frame Seal?
Blue71
Getting ready to put a lower windshield frame rubber seal on a '71. "The one that sits in the channel under the windshield frame." Does this need rubber seal to be siliconed/glued to the channel, or do these just lay in the channel and are sandwiched in there when you put the windshield frame back upright in original position?
Thanks,
Blue71
TheBroncoRanch
They just lay in there and pinch when the frame is in the upright position. How many broncos do you have;D
Blue71
Blue71
Thanks T. To many:) The couple that I have layed the frame down on, almost look like they had a sticky side facing the cowl. Guess that's from 30+ years of being there:)
A
NicksTrix
get a caulking gun of silcone and pump it full with half a tube, lay the seal in and pump out rest of tube ontop. pull windshield back and spread off the excess with the caulking corner tool you bought off tv. you're done now.
just kidding !! ;D;D;D
install dry. :p
Blue71
Blue71
install dry. :p
Nice!!!! Will "GOOP" work?;D;D;D;D;D;D
Andy
