Lowering Bestop
Fastwest
Has anyone lowered the bow height on a Bestop soft top to clear a garage door? Also, I think it might look a little better. Let me know what you have done. Pics would be great! Thanks!
You mean permanently? Or just for getting it into the garage?
There might be someone out there that has done a permanent job of it, but I have not seen, or remember seeing anyone even talk about it. Too much work it seems to me.
You'd have to modify the top in some pretty specialized ways to make it permanent.
But for just temporary, can't you just loosen the top material a bit (un-snap, or un-clip it) and then fold the bow slightly?
I'm more familiar with the Rampage/Kayline setup that lets you release tension on the main bow setup with a lever and more easily fiddle with the height.
But because you said it might look better, I presume you mean permanent-like. Be interesting to see if anyone has attempted it. But with rumpled windows and side panels and other parts to worry about, it would take some serious fiddling with the material I would think.
Good luck! Most probably just let air out of the tires if it's only an inch or so. How much are you going to need for clearance? Is it just the "hump" in the middle, or does the front riser hit also?
BGBronco
N A S H V I L L E
Tennessee
I think Bestop is a better made product but I ended up getting a Rampage for that specific reason.
SHX669
"Looking better" is a " relative " term ; personally I like the looks of the Besttop vs the flatter tops.
As far as design wise I think the center bow is taller because it's made to fold to the rear and lay flat on top of the rear bow so it has to clear most rollbars/ cages. This is when you want to go semi topless and fold the top down or remove the cloth part and don't want the frame sticking up in the air.
sprdv1
REBEL
just lowering the hoop to help a little.. no way to really lower it other wise
garberz
Bronco Influencer
Conejo Valley, Ca.
If you lowered the center bow, you’d need to do some alterations to the top so it maintains it’s tension. Finding someone to do that type of work would probably rather just start from scratch, and make a custom top.
Mark
Or just live with it and simply (relative term!) put it down any time you want to get it into the garage.
Then, if it's long term storage, put it back up to keep the dust out of the cabin.
F
Fastwest
I gotcha guys. I do currently lower it when bringing in the garage. It’s sooooo close! Maybe a 1/4” lower would clear. If I lower tire pressure it clears. I just like the look of it being just a bit lower. I can live with it until I find myself a hardtop.
abn373
Charleston, SC
Mine didn't clear until I adjusted the garage door opener stop up higher, just a bit. Not sure if that would help, especially if you are hitting the door frame, but just a thought in case you are overlooking the simple fix like I was.
F
Fastwest
Garage door is cranked all the way up. It’s a minor inconvenience to loosen the top down. Guess I’ll keep doing it, but I may look at some adjustments on the top.
abn373
Charleston, SC
Yeah, that has to be annoying. My old house had 8ft doors, but this house has standard height. I usually do bikini or nothing, but sometimes Bestop safari mode. I do agree, that if Bestop would have designed the bow and top just maybe an inch lower, the looks would be ten times better, regardless of garage door.
Deano
If you take the door brackets loose and let them hang down it should let that bow drop down a inch or so at least it does on mine it lays down on the front cage and gives me less hight
sprdv1
REBEL
yeah, it's always gonna be something..
sprdv1
REBEL
my bad luck of an old house, short azz garage here
