Question on Lowering Front Springs (Stance)
Justinkurn
Hey Guys,
Quick question just wanting to make sure I am thinking about this right. After finishing putting all the "extras" on the bronco, I have a little bit of a Nose Up stance, its exactly 1 inch. I have 3.5 springs in the front and 2.5 and a 1 inch block in the back (don't ask its a sore subject).
Anyway, I don't want to put a 2 inch block in the back and I don't really want to buy new 11 leaf springs at the right height because the ones in there are new. In terms of LOWERING the front spring to 2.5....are there any repercussions of doing that? Its the cheaper option and I just don't want to do something that is gonna cause an issue somewhere else (thinking about my alignment, linkage etc).
Any help is appreciated! Thank you!
J
Justinkurn
Yeah aftermarket rear tire rack/bumper, rear seat, family roll cage, thick carpet, dynomat etc. After it was all in it was just and inch below where I wanted it to be. Are you saying I can NOT lower the front springs 1 inch?
Pa PITT
Stephenville TEXAS
WHAT KIND OF BUMPER DO YOU HAVE UP FRONT.
If you want a nice big bumper & your running a stock bumper up front then maybe It's your chance to get the new bumper you want up front.
.... I was going to say ... DO YOU LIKE the hight of the rear best or do you like the front the best.
I've taken mine & put my floor jack under the rear bumper hitch .. & jacked it up an inch & then 2 inches on mine . I parked it in my drive way. Got my self a lawn chair & a couple of Adult Beverages & set there looking at mine for quite a while . raising & lowering the back .
... My front was where I wanted it. SO I was trying to decide how much I wanted in the rear... After a while I just went with the 2 inch aluminum block in the rear.
& I love it . cost less & was very easy to install. & I did not want the stiff ride of the 11 pack coils in my rear.
......... & You can add a 100 lbs up front & see if that pushes your front end down .
... Now I'm a farmer so I have about a 1000lb of tractor weights laying around . But 4 sacks of 50lb feed or 80 lb bags of concrete lay on the front of the hood.
A FEW HEAVY BARS or pipes On your front bumper . could mash it so you can see how the front looks pushed down.
... But My front rode like I wanted & I sure didn't want to change that .
..... & You could advertise in the part wanted section & buy good spring front or rear from some member here .
As far as the spring change goes, there is nothing at all wrong with dropping the front with a pair of coil springs. Nothing needs to change between 2.5 and 3.5 and unless you have shocks that are near the limits for some reason, you should not need new ones of those either. Depends on the setup of course, but in most cases a 2.5 and a 3.5 use the same shocks.
No need to change to a different pitman arm or trackbar drop. No need for shorter brake lines. No need for an alignment (other than to just check to see what you have).
And changing the front springs is still one of the easiest jobs on a Bronco.
Will your existing springs settle? Maybe, maybe not. But an inch? Not for a very long time, if ever.
As asked though, do you anticipate any more weight added to the front? If so you may want to wait until that happens. Although, at still under $200 bucks, a pair of springs is not a huge investment in happiness even in the short term. If you add more weight later, or buy new rear springs that end up sitting higher in the rear than they do now, you can always throw your old coils back in to bring it back up that inch.
bigmuddy
Marthasville Missouri
Good points, PA/Paul!
I have a fairly heavy bumper with a 9000ln warn winch. With it installed it sits fairly level. Without it on the bronco it raises at least an inch. On the rear I have a tube bumper with tire carrier, 35" tires on 5x10, hi lift jack and sometime 5 gal of gas. Now I am adding a hard top back to the bronco and I will have to easily add either a lift block or another set of rear springs (probably springs) As I also have asperations of hauling a small tear drop.
It's a balancing act to get the stance right. I like Paul's idea to buy a new set and see how it goes over time.
