LOWERING my Bronco
77bronco_ed
Just plan on heading to the Broncorama in May... From there it is not to far ;)
You can meet up with plenty of folks on the board.
greatguy57078
greatguy57078
Wwow! This thread was waaaaay back opn page 11? I guess it has been awhile since I have posted anything. I had a few setbacks with the home furnace going down and the new garage heater taking a bit longer to get things up to temp in the middle of 4 degree weather.
With all that behind me now I can get some work done tomorrow. At least I will get the front end back together and maybe even make up my mind which aftermarket harness to buy, or to just go with a OEM one.
On another note. Here is a really sweet 1947 tailgate that I found over in Iowa. Thanks to eaglesnest66 (Tim), who not only picked it up but had it sent close enough to me to make the pick up. Man this thing is nice. Will make a very smooth custom tailgate, as was just what I was looking for. More pics and updates to come, now that my garage is a steady 62 degreees! :cool:
greatguy57078
greatguy57078
Well I got the front end components all installed. After all the issues I had with the two different sets of coil springs I bought, I was quite pleased with the QA1 coilovers I finally settled on. They were a breeze to install, and from what I can see should level out nicely once I have the body on the frame.
You can see in the pics that the a-arms are not quite level, but with the weight of the trans,body, seats I think I will have the ride I am looking for. Thank you Bill (behemoth) for suggesting the coilovers. Even if they don't sit level after the added weight, I have lots of adjustment with the springs. I know it may seem like no big deal to alot of you guys with more time and experience, but it is a big deal to me. At last! At least it can roll around! Woo Hoo!;D
ryoungbronco
Belmar, NJ
I can appreciate the feeling of accomplishment. Every step, even the little ones, are like winning the lottery. Keep up the good work. I'm enjoying watching the transformation on this one. The uniqueness of the build makes it that much more fun to see.
greatguy57078
greatguy57078
Yeah. Now I can't wait to get the body off the original frame and set it on this frame. As you can tell by the truck topper across the frame, and all the other parts stacked around it I have waaaaaay too much.....stuff. %)
The other good news is that the Marley garage heater kicks (_!_)! :cool:
chrlsful
yeah, st rod or wheeler?
Junior sez "Multipurpose is no purpose", but Bronks know different...
behemoth
Looking good, I have actually adjusted mine six turns up from the bottom, and given them 3 clicks +, I think 2 clicks would be perfect now with the sway bar installed. It tucks up nice behind the stock bronco cross member and up close to the rack.
Im looking into slam bags for the rear and better shocks, I think i will be fine at that poiint.
Heres a shot of me and the oldest boy out for a turkey day drive. It was only 36* on the way home.
greatguy57078
greatguy57078
Looks good. Thanks for sharing! 36 degrees would qualify as a heat wave here! My daughter moved out to San Diego cause she hates the winter weather! Haha!:cool:
blazinchuck
how goes these lowered broncos??? im fighting the demons to ditch the offroader (FBG) and pursue a lowered bronco
chrlsful
a different world, "blazin". anything on rd has 'legalities' to contend with. No thanks, don't wanna color inside the lines. Them that do sure have my respects cuz that's another set of constraints to deal with (like: beauty, laws of physics, $, etc). I got more n enuff to handle. The few times I gotta go down the rd for a job I look smart for the man. Each time I go by expectin something from em. I think I'm saved by the age a the rig and their lack of desire to get involved in ticket writing/court attending.
greatguy57078
greatguy57078
I am working trying to get a fuel tank made so I can run fuel and brake lines while the frame is easy to get at. I would really like to get this done so that I can set the tub on the frame and see what the ride is going to look like! %)
greatguy57078
greatguy57078
Well I am starting to get going again. I installed the Moroso remote oil adapter today, and tried to line the headers back up again. I will have to lift the motor back up to get the headers back in place to take a few last measurements. I got five of the six body bolts out (yeah the back two snapped off). The drivers side will have to be cut as the head is so rusted that there is nothing to get a wrench on anymore.
The floors will be cut out next I suppose. With the top chopped I will be wedging myself inside the cab to drive it, and I am less than 5'6". I did also buy a Ididit 2.5" column drop to bring the steering into alignment better. After I looked at it (using Paint to draw lines), it looks like the angle would be much better with it lower and possibly trim something off the end of the column. I will be using a '78-'79 Bronco tilt column, so hopefully after it's all done I will be able to manuever easier under the steering wheel.
My main concern is that I want to be able to get taller people into the cab without them having to wedge into it and be uncomfortable. My brother is alot taller and I would like to include him as he has been a huge help with this project (yeah he owns the parts store!).
I will try to post pics tomorrow. It is supposed to be in the 60's here so I took the day off. I have to drop my GT40 heads off at the machine shop, and degrease the back of my poor pickup. The Explorer engine that was back there leaked and my son powerwashed the tranny out of my '68 in the box. Yeah, he was supposed to take it out of the truck first, but you know how teenagers are! %)
chrlsful
still watchin (& askin bout the frnt bench +).
Tell me bout this "Ididit 2.5 column drop" (bracket?), if U will. I have the same tilt wheel & am tryin ideas...want to get my legs out straight like a modern vehicle (bronk's like sittin @ the kitchen table!) and bring my line of sight down offa the top of the windshield. I can't shrink 1 ft to your size & was thinkin ("Uh oh, there U go again, Chad - makin trouble!") of removing the floor rise over the aux tank/under the driver's seat. But I DO wanna keep the aux...
Could the 2.5 help? How does it wrk?
TIA!
greatguy57078
greatguy57078
Well I chopped my top 3" so the steering wheel sits and looks too high. I also have to be able to line up the column with the Mustang II rack, so it would be very beneficial to lower it to bring it in at a lesser angle.
I am going to cut the floor down (remove the raised sections), and move the halfcab bulkhead to a straight up and down position. This will allow the seats to sit lower, and at the same time give me more room to move the seats back. I also gain storage space behind the seat if/when needed.
greatguy57078
greatguy57078
You can see that the column rests up against the bottom of the firewall where the brace bolts onto. The Ididit (Part #446-3234) drop is supposed to be a 2.5" drop for a 2.25" diameter column, but it looks to be closer to a 1.5" drop the way it would bolt up. Another great thing about this drop bracket is it looks to fit right into the original holes.
As you can see in the first pic it should basically move the column from the top of the opening to the bottom. They do sell a 3.5" drop bracket, but I am afraid that it might move it too far and the bracket would hit the bottom of the hole in the dash. %)
I was going to machine this drop bracket at work, but would have had to use a protracter and mill the hole at the angle I thought would work. Then I found this bracket that Ididit makes that swivels on a hinge, so I decided to go with a purchased one instead of spending time and effort making one that might not work as well.
chrlsful
ster. column drop
The Ididit (Part #446-3234) drop is supposed to be a 2.5" drop for a 2.25" diameter column, but it looks to be closer to a 1.5" dropthe way it would bolt up. Another great thing about this drop bracket is it looks to fit right into the original holes....They do sell a 3.5" drop bracket, but I am afraid that it might move it too far and the bracket would hit the bottom of the hole in the dash. %)
Thanks Doood! very helpful! Time to go brush my tooth so will ck in detail in the am (1.5 hr past 'my time' 10 vs 11:30)...
