LOWERING my Bronco
77bronco_ed
I went ahead and am having a complete 2x4 frame made up. I am hoping it will be finished mid April. My work will be reduced to engine mounts, body mounting and trans crossmember mounts. This will give me a big jump and renewed motivation for the spring/summer months.
Then... I can just focus on the body which will be a ton of work on it's own.
greatguy57078
greatguy57078
Yes I took 6 1/2 inches out of the bumper, 3 1/4 from each side hidden by the bumperettes. I will sand down the welds and get it re chromed at some point here if and when I ever get it painted.
Yeah Marty how are you healing up ?
I am doing better every day. Last time I stand in the goal at soccer practice. I blocked a ball which drove my arm up and back, at which time the bone spurs in my rotator cuff (old age) severed the muscles and tendons. Strange thing is I never really felt that bad until a month later after pushing/pulling at work it must have tore more. Every time I layed down at night my shoulder would separate (several times some nights). I had to endure the pain for another month before they could do the repair.
Anyways, after doing some pricing I think instead of paying for the labor I will buy a big air compressor and tackle my floors and body myself. Sounds like after years of coaching the board has decided to give the job to another coach. No worries. I can use a break and get some work done this summer and fall on my Bronco projects.
As far as your bumper, I was thinking of doing that same thing with a little more angle down and some small driving lights. I also found a really nice Maverick Grabber hood that I am thinking of grafting the 1" cowl onto my Bronco hood. I am done with my physical therapy, but am just starting to lift and get back into shape. After sitting in a recliner for 6 weeks I gained 20+ pounds! Like I needed that! %)
77bronco_ed
Guys,
Going through this do you see any advantages/ dis-advantages between 55" front track width opposed to a 56" front track width?
Thanks,
-Ed
behemoth
At my height and track width which I do not remember along with the 1/2 spacers and mustang rims. I need to roll the fender lips a bunch, they hit now just turning with a turn and compression they would rub a bit more. So to me the narrower would avoid some of this, but again so would not going as low as I did.
77bronco_ed
I just wanted to make sure it would not have a large adverse affect.
I did not buy my front wheels yet, so when ordering I can make sure any offset in the wheel also helps to avoid issues.
Thanks,
-Ed
behemoth
So as I rebuild it from the wreck I have the opportunity to have it painted. The wife likes the brown so that part is easy.
1. Keep or loose the rocker trim? I have clips and another set of rocker trim as spares if needed.
2. Hidden hinges?
3. Suicide doors?
Both 2and3 are equal work.
4. Lower or chop the front windshield frame loosing wipers all together?
If done then a hard top will never go back on.
Lots to think about, the biggest one is the suicide doors, that and lowering the rear more which il going to do as I want a level ride height no stink bug look.
Will the suicide doors be to much? Will they take away from the stock bronco look too much?
I'm working slower this time. I'm still re making my custom inner fenders, they will be two prices like stock this time unlike 4 last time.
77bronco_ed
I went back in and took a look at the rocker trim... I personally like it without.
The hidden hinges is a clean look. I think there are a couple to look at it to help you decide.
Lowering the rear would be nice...As we are finding it is tuff without making some serious modifications.
I really am starting to like the look of the chopped windshield frame without a top. I do know I will be running mine like that Although I believe you could still get the top chopped to match but then there may be the head height issue to deal with if the floor pans are stock height...
I think it all depends on how long you want it to sit again... I am sure you had fun as it is.
Willing to have it sit for a while again? I see they never get done as fast as we would like.
I picked up my frame, going to get moving again... posted a few pics on my thread!
-Ed
behemoth
Dropping the rear more means cutting the bed something I did not want to do but after rebuilding the front inner fenders I'm ok with it.
Hidden hinges is something that I want to do just can't commit to the suicide option. Just going hidden with the standard opening is easy as all you have to do is remove the fender to weld the supports in. Going suicde requires you cut some of the inner structure away to access the door posts as well as the doors.
The window frame well that one is a bigger issue but that is only a problem if I plan on putting a top back on it.
How long it sits is the issue, I guess I got a taste of the fun and that is the question I have to ask myself.
Each decision opens another pandoras box right now.
77bronco_ed
My 4x4 truck was sitting so long I really never had a chance to use it much. It still is not exactly as I wanted but I am finally having fun with it! I am not going that route again.
As soon as I have something that can be used it will be on the road, and...will be work in process. Rainy weekends or winter work ;)
They are not as much fun when sitting in the garage.
My advice...Get it back on the road, have fun and do your upgrades when something is blocking you from having it out.
greatguy57078
greatguy57078
I have the hidden hinge/suicide kit. I played with the idea of suicide, but the only time you will notice is when the doors are open. Yeah, there is always the "cool factor". Hidden hinges and shaving the handles would work and look the same.
After paying alot of money to chop the 1/2 cab, I wonder if that was worth it (sometimes). I figure if I have my way I would chrome the windshield and run roadster style. I did rake my windshield back, so I think that would look cool also.
As far as the rear end height you are looking at, I would be satisfied just to get it so I could drive it. In my eyes these hotrod Broncos couldn't look much cooler. It is all in the eyes of the beholder ... right? ;)
KS.76Sport
Wichita, KS.
2. Hidden hinges?
3. Suicide doors?
2c from an observer. Been following this thread since the beginning and I have to tell you that I think your "rodded" bronco is the best looking one I’ve seen yet. The reason why is that you haven’t done a ton of mods to the body (chopped it up). Dunno, the "stock" part of it lets it remain tough, rough, utilitarian, but everyone knows that it’s a completely different animal underneath. I wouldnt cut nuthin, and I personally like the rocker trim and the body trim too. To each his own, just thought I would let you know how I felt about your sweet ride.
BTW Good choice sticking with that goldishbrown, I think its a perfect color for it.
Peace
behemoth
Well after some setbacks and I do not currently like the way these look I am again at a stand still. I had hoped for tighter bends on the edges I guess the nature of the design does not allow it.
This is the current inner fender setup that I am thinking about. I chose to try and make these from two pieces of steel vs the 4 pieces last time I had hoped for less welding and less body work on an inner fender. The inner fenders are a big part of the strength of the front end.
Well I am open to thoughts or suggestions. ImageUploadedByTapatalk1338000052.101548.jpg ImageUploadedByTapatalk1338000067.014738.jpg
behemoth
Thanks for the comments all. I will skin these and see what they look like and if I can deal with or hide the issues I have with them.
Once I decide upon the inners then I guess I will have to decide upon door hinges, I am leading towards the hidden hinges non suicide, and keeping the door handle and lock at the moment. My original thought was to keep it stock looking only lowered. I am there and I guess some fine tuning of what look I want. I will drop the rear some more and raise the rear bed instead of cutting it up, I will probably not continue with the air bags. I like the simplicity of the coil over shocks and the ease of adjustments of them in setting ride height and performance. With coil overs and the height I will be at changing the rear tires will be a pain. ImageUploadedByTapatalk1338010072.418989.jpg Here is one with a template skin on it I have to cycle the front and check clearance. With these inner fenders the battery is not up front anymore.
Lots to think about yet.
77bronco_ed
Well I am open to thoughts or suggestions. View attachment 259481 View attachment 259482
Inners look good!
77bronco_ed
I had some set backs.... I had to take my rear end up for some modifications.
The frame back half is slightly different which the ladder bar dimensions are narrower.
I have the body sitting on the new frame now. but... can't get final position until I get the rear end back. I think I may need to get some rollers and set up a fender to make sure the front is also positioned correctly before making body mounts.
Have the engine on the picker... This weekend I will move it between the rails to start taking a look.
So much for a budget build...
behemoth
Well here is the passenger side inner skinned. The drivers side is not cooperating at this time. ImageUploadedByTapatalk1339385486.817793.jpg
77bronco_ed
Looks like the inners are coming along.
While waiting for the rear end to get modified I nested the 4.6 between the frame rails.
Yikes it is huge. I had to take the starter and the oil filter off. I see that I will need to set up a remote filter no room at all for the filter to go back on.
Once in place it looks like the starter should go back on. The exhaust manifolds are still on as well. The engine came with stock rubber mounts. I will need to create a steel mounting for the original mounts to bolt to.
I should get the rear end back this weekend.
