LOWERING my Bronco
greatguy57078
greatguy57078
Well the 3rd time is a charm ... or was it 4x? %)
I got the rear axle back in tonight. When I first started with the 9" rear end, I had my doubts about moving that chunk around by myself. In the process I have gotten pretty good at it ... especially with 2 rebuilt shoulders!
I have the ride height set and the everything moves up and down as it should. I should have the new (shorter) shocks sometime later this week, and then I will have everything bolted back up and see where I land. At least for now....the rear end clears the crossmember....barely.
I will still probably pull everything one more time and cut a notch just so I don't find out the hard way that it DOESN'T barely clear. :-X
On to the brakes and steering next. It's a slow process but I am wishfull thinking that we will make Deadwood by this August! :cool:
behemoth
I would not notch as high as I did this time again. Things like driveshafts and floor birds really start to compete for space. Progress is progress.
greatguy57078
greatguy57078
Good to know. I'm still binding somewhere ... Maybe that panhard bar. I'm going to go out and crawl under and see what I can see. Maybe I can get the wifey to run the engine hoist up and down for me. ��
greatguy57078
greatguy57078
Got the fat piggy back rolling on the new wheels and tires. Added a little more bling factor along the way. Removed the 1" spacers and went with 18x9.5's (255) up front and 20x10's (275) in the rear. I actually did the math right and now have about 3/8" of an inch between the tire and wheel well, and right at 2" inside to wheel well.
greatguy57078
greatguy57078
Now on to the steering. It is going to be tight, but nothing new there. After stuffing that 4.6 DOHC under the hood it almost seems normal with this project. %)
I don't have a lot of extra space (as you can see in the pics). I am ordering a custom length Ididit tilt column 5" shorter than stock. The new shorter column can only come through the firewall just long enough to rest on the column support bracket. I will even cut 1/2" off the end of the bracket to give me a little more wiggle room with the 3/4" splined shaft.
I had the wifey hold up a 3/4" jack handle to mock it up and see approximately where I will come out at ... and it looks like I might get lucky. That has not been the case this whole time, so I'm not counting on that just yet!
behemoth
Just a thought but if needed, does the steering column need to be supported on the engine side? Why not support it at the firewall cabin side to pull a little more angle out of column, these steering joints have bind limits I had to clearance one a little.
greatguy57078
greatguy57078
There's a thought. I do have a hotrod drop mount around here somewhere. I thought I would use the stock mount to keep everything lined up, but maybe I should play with that aluminum mount a little. Anyone ever try fabbing the original to mount INSIDE? I could pick up a few degrees going shorter with the column.
behemoth
I like the wheels, I've been thinking about bigger/ wider as well. This is a pic of today's success, it's low it could be driven this low but it's on the bumps.
drive shaft clears the center link and the cross member.
greatguy57078
greatguy57078
Ok so I have an idea. I am going to take the OEM Bronco firewall column mount and flip it so that the mounting flange area is inside the cab. I will heat it up to get the right angle, and trim it in so that it ends up fitting flush against the firewall.
This would move the clamping point for the column inside the cab under the dash, which would allow me to trim off about 6" off the column, and start closer out of the firewall with the 3/4" shaft. The closer to the firewall that I start the smaller diameter 3/4" shaft, the better angle I have to use 2 U-joints to get me from the column to the steering rack.
Best of all it allows me to use the original Bronco column mount. Any thoughts? %)
behemoth
Check out a 68 f100 column and shaft, the plus side is that they have the smooth column, they are quite short.
greatguy57078
greatguy57078
I am putting off buying the column until I get the steering shaft mocked up from the rack up to the bottom of the column location. Either way with the 4.6 DOHC there is only one area that I can sneak a shaft through (between the header and frame rail).
I bought the Borgeson double joints and I am waiting for the 3/4" DD shaft to come in Friday. I may have to push the column over to the left as far as it will go, but I guess whatever it takes because I am committed with the 4.6 at this point.
blazinchuck
that sure is tight....hope it works out good. those wheels...ugh!!!!! im so jelly!!!!!(thats a good ugh) lol
maybe i should just say...em fawk
greatguy57078
greatguy57078
I can't really get a good pic inside the garage. Hopefully in the next week or two I can STEER it out the door to take some better pics!
77bronco_ed
Hey guys Broncos are looking good… Nice to see progress...
Into a smaller house and garage, hopefully I can get the garage in decent shape this summer so I can pick up on the Bronco. Had to get through a lot last year.
behemoth
Here is the new rear suspension, need to tune it, bleed the brakes, set the pinion angle and enjoy. The bed floor will come later. Thinking of putting it on a hinge for easier shock tuning.
