LOWERING my Bronco
greatguy57078
greatguy57078
And let's not forget the front bumper. :cool:
greatguy57078
greatguy57078
Yes I will notch the bottom of the grill to allow the bumper to contact the brackets. I will then grind the bumper for clearance to get it as tight against the grill as I can it without rubbing. The necessary modifications will be made and then the bumper re-chromed.
It is actually a 1965 Mustang rear bumper. ��
greatguy57078
greatguy57078
The rear bumper is mounted solid. This is bolted through the tailgate and is purely for looks. I thought it looked too tall top to bottom, so the bumper shortens it up in my eyes. I may eventually cut the bumper into 3 sections, but for now the tailgate still opens and closes as is.
I am adding a 1.5" x 2.5" x .250 wall tubing directly under the bumper/tailgate that will be "hidden" bumper. The roll pan/rear valance will attach to this tubing, while also functioning as a rear bumper.
greatguy57078
greatguy57078
I am well aware of how much that gas tank shows. I may have to go back to the bed mounted tank that I had picked out originally. A friend suggested painting the tank black so it wouldn't show as much. Any thoughts?
behemoth
I wanted more fuel than a stock tank would provide, but now that I have driven it the added capacity has not been needed. So a stock tank setup for efi would have worked fine for me to date. I'm planning a 700 mile round trip soon so we'll see how I feel after that.
behemoth
So I'm not a fan of a bigger tank in the bed. If your going to do that just cut the bed and move it up and this tank with it. I think a big fat explosive sticker is all that is needed on your tank. I left mine shiny and you see it clearly but the stock tank is also really visible.
greatguy57078
greatguy57078
So can you convert the stock tank? I always wanted a stock looking 16-18 galling tank...but I could never find one. A custom one is not in my price range. I would rather spend that money on interior and/or air conditioning!
chrlsful
answer (1 among many) cut bed, shove it UP, cover it w/seat.
2nd - use only aux tank*in stock location*(duz it fit there w/lowering u done?)
BTW: I like rear bumper w/'valance' under it as "tacked on" w/welding vice grips. Tryin 2 B membah frnt bumper…
yeah - frnt bumper looks very weird in this guy's opinion. Flip it regular (back down as in oem 'stang). Y not 'smooth it' into position like rear by sllicin out top profile (scribing [it to fit] we call it in the wood trades) &/or bottom profile (the lip where in curves around underneath/above throughout the whole length)? Cut off the legs of the "C" as seen in profile as viewing it on edge. Hard 4 me 2 describe, no?
Have fun, B safe AND productive.
greatguy57078
greatguy57078
How did that tank line up with the existing filler neck? Looks like a nice option for a few extra gallons with better looks than most 23 gallon. Is it mounted up against floor with universal straps?
I bolted the tank through the frame and through the tank flange. I made a small notch to accommodate the neck through the top corner of the frame, but I tested it by taking it in and out a couple times. It will line up nicely with the rear filler neck.
Maybe I will just leave it and see what it looks like with the valance/roll pan and exhaust shooting out the back. I may have to run the exhaust out the sides behind the doors. Wait and see...
chrlsful
/OR/
"...what it looks like with the valance/roll pan…"
datildoit, no?
can the pipes go out infrnt of the rear wheels?
greatguy57078
greatguy57078
/OR/
datildoit, no?
That is a possibility. Moving the tank into the bed area (behind the bulkhead)would create more options.
roundhouse
You could build a pork chop shaped tank to fit over the rear fenders inside the bed
I'd like to see what the front would look like using the same bumper you have in the back
behemoth
Putting the tank in the frame in front of the axle behind the bulkhead may be an issue with drive shaft clearance depending upon how low you go.
The stock tanks can be fitted with a n in tank pump and a return line. Does your efi system require a return line? Don't think so. So a stock tank and a hi volume/pressure external pump is an option.
greatguy57078
greatguy57078
Is there an article/thread that shows how this is accomplished?
GRN_MEANIE
I bought a stock 1992 Mustang pump. It slid right in the hole in a new stock plastic tank. You will need to put another hole in for an aftermarket level sender
behemoth
I bought a late model bronco 87 fuel tank sender with the return line already in the top. It was already setup for an in tank pump, all that it appeared to require was some bending/trimming of the tube to work in the stock early bronco tank.
I did not complete the project as I ended up with the brother in laws tank in the truck.
greatguy57078
greatguy57078
I am still waiting for my aluminum channel to show up so I can work on the radiator and hoses. I am sending the thermostat housing and crossover tube to be Jet-Hot coated. The crossover tube itself is known for rusting out from the inside, so I thought that I should get it coated as it wasn't easy finding one in great condition.
77bronco_ed
How is progress, I have not been on in a while so I have tried to get caught up on where you guys were at... No posts lately
-Ed
