LOWERING my Bronco
behemoth
That is the kit, you and I spoke of before. I will get the truck to ride height pull the tire and set one of the plates in place to see what I will gain. I am leaning toward coil overs and the triangled 4 link for the rear. this will eliminate the leafs and give me better height control or so I think.
Reading the instructions tonight as tomorrow I hope to set the cross member in place. Some concerns I have with doing this is that ride height and the rest of the measurements now are with no engine,trans, and an empty tank.
More pics to come. I hope to have good progress tomorrow.
Bill
uncle ray
you can get narrower than stock control arms from some street rod suppliers, i believe speedway motors has arms that are 5/8 narrower each.
an airbag suspension is very competitively priced compared to coilovers. there is a guy on the HAMB that sells airlift crafter packs for $800 or so. he just had a sale on them for $550! that includes everything you need except bag mounts. slam it, stance is everything!
behemoth
No real progress today I was a little to frustrated and out of it to make any good decisions. I also believe that the ground it is sitting on needs to be level in order to get the correct angles for the crossmember. I have a slope in my garage and it is on stands so I am not able to move it easily.
So I will attempt to place it up on plywood and give it a level base. The frame is already showing me that it is not level side to side anymore. There is no fixing that one though.
After that I hope to decide on some things and cut the crossmember.
Oh well there is always another day.
BIll
behemoth
Ok I have set the ride height and it is only a little higher than number 2 photo. I figure that the tire will move enough to clear the wheel well, at best I have to roll the fender lip.
The delema today was level.
My garage floor slopes about 2 1/2 inches over the lenght of the bronco. So just for chuckles lets call that a 3* slope ( just for chuckles I have had enough math for one day).
You set the rake of the truck with the ride height front and rear. the cross member is welded in level. The hats or upper a arms are set with a 3* tilt to the rear. They nicely included some plate guides to set this 3* tilt. So what I figure is that if I weld this thing in as it sits now, on level ground I will have a 6* tilt to the rear on the front suspension. This is not good as I figure now.
So now I feel I need to level the work surface and check all measurements again. Then I will have the balls to cut the cross member and go forward.
If my head up my butt logic today is way off let me know.
greatguy57078
greatguy57078
I will post information as I receive it. I should have something by tomorrow as far as where exactly the crossmember is to be located. Sorry I can't get something sooner, but I am in South Dakota, and the measuring is being done in Wisconsin. Confusing huh?%)
behemoth
It will be good to compare what he has done to what I was just told by Heidts.
I spent a good amoung of time on the phone with their tech support as I could not grasp the simplicity of the instructions. Add or subtract measure up or down.... etc which one is it dammit.
Anyway it is really simple, because the broncos frame archs up at the firewall we are pretty much locked in to one height for the front. Unless you notch the frame where the crossmember would sit.
******** All this is based upon my frame dimentions *************
So what I was told today is. The spindle height is 1/2" below the frame rail. The horizontal cuts in the crossmember are 4" above the lower control arm bolt center. The vertical cuts are 11 7/8 out from center on the crossmember.
Ride height at this point for the front is freaking in the weeds low but it leaves enough crossmember and hat to adjust alignment with the t bolts.
I am curious to see what his measurements come out like compared to what the tech support and the engineer came up with today. They put my data into their cad and came up with these dimensions.
I will be cutting stuff up tomorrow and going forward.
They also make a 4 link kit for a nova that sounds like a possible fit for us on the bronco rear. I will unfortunatly be cutting into the bed to achieve the height in the rear I want. Better ride, bigger cut, nuff said.
Keep it coming.
Bill
Oh yeah we are not alone there another in washington state that is already completed. Silver or blue I am told.....
73stallion
Eugene, OR
bill why not just cut a notch out of the bottom of the frame and close it in with plate or a half section of pipe if you do it round? then plate the sides and top. how much extra room do you need?
greatguy57078
greatguy57078
This is a pic of what has been done for this very same project. I have also included a pic of the notch kit you can buy. It is bigger than you need but can be trimmed down to fit whatever material you remove. The third pic is the kit installed. As I said, it shows it a bit larger than you would need for a Bronco, but you get the idea. The one I received is not quite as big as in the pic, but you get the picture.
behemoth
That notch kit is what I have, the height at which I am setting the rear to will be much lower than Dale. I am going for level to little rake. At this point it is only a guess, I believe the explorer sway bar mounts on the axle are resting on the frame in pic 2. We will see, again the notch is dependant upon how nice or harsh of a ride you want. I have been told a minimum of 2" of travel, and I am shooting for at least 5" . If I cut the floor so be it, I am going to run a cover on the bed anyway so you will not see it.
Getting wound up now, trans will be done tonight, the front will be dealt with tomorrow. the rear afterward. Then its up to the ups guy for the other parts that are needed for it. They have all been ordered just need them to arrive.
I am really curious as to Dales measurements, a shot of his frame in the rear with the body on would be wonderful as well.
Bill
greatguy57078
greatguy57078
Here is the only pic I have from the rear with the body on the frame. I have included a pic of the chassis only. He is going to send me measurements tonight or tomorrow.
greatguy57078
greatguy57078
Here is the info Dale gave me. Please let me know if there is anything else you need. Hope this helps to keep you going.
Here are the
measurements:
The notch for the rear axle is 1.75" up into the
frame. I went up 1.25 on top for reinforcement
and it works fine.
From the floor to the center of the spindle is
12.75"
From the floor to the bottom of the frame is
14.0"
The upper A arm mount is 1.625" above the top of
the frame at the front and 1.0" above the frame
at the rear of the mount.
behemoth
Wonderful, it is always nice to have something to compare to when you are making cuts on a nice cheap piece of steel.
Everything checks out between what he did and what Heidts told me.
The layout for the cuts has been done, tomorrow the cuts and tack welding begins. Its a bit of work but should be a whole lot of fun.
Thanks.
behemoth
No pics from the last weeks work. The cross member is tacked in place, that is it basically. Association has shut me down for a while. No big deal really needed to slow down and get some other things done/ ready anyway.
Nothing like having a new neighbor move in and become one of the committee members, and then not appreciate the beautiful sounds of the angle grinder.
Setting the height of the cross member was supposed to be the easy part. There was a lot to consider. A level work surface is important, as all frame dimensions are off of it.
The hats take more time, but unless you want to cut your inner fenders needlessly the body comes off at this point. So that is where I stopped. If I am going to pull the body I will do the c notch at the same time.
There will also be some ridiculous cleaning and painting of things nobody will see.
Thanks again for the information to compare my mess to.
Bill
greatguy57078
greatguy57078
Did you go with the measurements I sent you, or did you do something a little different? I would like to see where you cut the crossmember at, if you took any pics of that. Just curious....and getting very anxious here!
behemoth
The measurements I took and have are about the same as what Dale did. You are really limited to what you can do with the front because of the frame shape.
There are two measurements that you can not change according to Heidts.
The upper arm mounts are 9 1/4" up from the lower control arm bolts at the front. The rear are 8 7/8" up from the lower control arm bolts. The upper arm mounting surface is at a minimum 1" above the frame at the rear. This is for alignment options. The spindle center line is 3 1/2" up from the lower control arm bolt center.
So if you transfer these measurements to paper or metal as a jig you can easily see where you will have to place it. Front ride height is basically set, no real choice.
I have to cut the tack welds and trim the crossmember up some to get it to set nice and tight to the frame while maintaining level.
I have to do this with the door closed now to keep the neighbors happy.%)
greatguy57078
greatguy57078
I was just wondering if you were making progress. It's soccer season here now, so I don't know when I will get started. They are supposed to start doing my 3" chop sometine this spring yet. So much to do, and so little time.....and money.
