LS Powerplants
El_Ducko
LA LA Land
Are you seeing any other clearance issues besides the passenger header?
Steering?
Brake Booster?
What radiator are you planning on running?
Ss69
Chattanooga TN
Steering?
Brake Booster?
With my headers, looks like steering column will be ok. As will be the manual brake setup. Unsure about a power brake setup but I'm sure an angled bracket would fit no problem. I'm crossing my fingers and hoping I can find some hoses and my stock radiator will be ok but i won't be surprised if it won't.
El_Ducko
LA LA Land
Any updates?
Hemi
Mine is up and running. Took it to pismo beach and ran great.
RJGarza
Karnes City
Any updates on builds?
The time has come for my LS build to begin! I'm pretty much finished with the frame on my '66 and now all I'm lacking is the drivetrain. Found an '02 Tahoe I'll possibly be getting for $800. It's a 2wd but it'll work with my D20 tcase with an adapter from advance adapters. I was curious about motor mounts. What mounts did y'all use? How far forward/backwards did y'all have to move the motor mounts from the factory location? My tub is off the frame so fitment will be nothing but measuring exactly where the body should be sitting, sort of a guessing game. I'm wanting to do the motor/trans swap while the tub is off the chassis for a more simple install.
RJGarza
Karnes City
I'm also curious as to what y'all guys did with the fuel system. Are y'all using in-tank fuel pumps or in-line mounted?
Yeller
Rogers County Oklahoma
I have an inline with the corvette filter/regulator (later model is return-less at the fuel rail). Am going to switch to intank, can't seem to get a pump that is quiet enough to not make me crazy, I'm building a new tank from scratch so why not while I'm at it and using a late model pick up makes the baffling simple along with a fuel gauge. And I don't want to do a dual pump set up with the remote reservoir.
RJGarza
Karnes City
I searched at the first few pages of this topic and found a nice fuel pump kit that someone had posted a link to. I may just go that route and save myself the headache. The more I read and dig into research, the easier this swap should be. The only thing I know I won't be able to do is all the wiring. I can mount the motor and transmission with no problem, it's all the wiring that would confuse the hell out of me.
Yeller
That kit from speedway is what I'm running, simple and has all the parts needed except the hose.
The wiring is not as complicated as you might think. a good harness will have a ground, battery hot, key on hot, signal wire for fuel pump relay, wire for the idiot light on the alternator and a check engine light. Some harnesses do not use the check engine light or alternator light.
I used to build my own harnesses for TBI motors, did my 1st conversion in 89.... but with the cost of aftermarket harnesses and what some reputable shops charge to do these motors, no way I'm spending my time building a harness.
RJGarza
Karnes City
There's a guy somewhat local to me (60 miles from me) who builds harness' for LS swapped vehicles. I may just install the drivetrain and haul my bronco to him, let him do all that stuff for me.
RJGarza
Karnes City
Picked up my donor vehicle this past Wednesday, 2002 Chevy Suburban Z71 model. The 5.3 has 158k miles but the motor is extremely clean and very well maintained! Stock transmission and tcase (4L60E, I'm unsure of the tcase). Will the stock tcase work? It's a driver side drop and so is the D44 EB front axle. Only problem is it's an electric tcase.
Yeller
The case may work but is very long and wide. By the time you spend the money to shorten it with a slip yolk eliminator(if even available, can't remember all the differences) you can just about adapt to a 20 or have a nice chunk towards an atlas. I know of one that used a 231 of of an s10 that fit pretty well but still had to do a slip yolk eliminator.
Yeller
Not necessarily but there are better options the factory case is huge. Having been there and done that I would look for a 231 with a slip yolk eliminator or adapt a 20
RJGarza
Karnes City
I'm probably better off just adapting the stock D20 to the 4L60E. It seems like the cheaper way out. It'll save me some time from having to find a 231.
RJGarza
Karnes City
LOL @ EFI GUY. My little boy is due March 5th. Gotta LS swap the bronco so I can have reliable transportation to pick him up from school.
EFI Guy
TheEFIguy@gmail
BFE
Congratulations on your son, that's awesome!
I read the second part as you have 5 years to figure out the Coyote swap before he starts school though.
