jspurl3
I'm finishing a project for a friend. He had a M5OD with the ZF bc bronco conversion package. I went to bleed the hydraulic clutch setup and its leaking right where it enters the slave cylinder. I think he forgot to put that little O-ring between the line and the slave cylinder. Is there any way for me to push out the roll pin and disconnect that line to install the O-ring without pulling the trans off the engine?
I'm open to any trick as I can look at it but no clue what tool from the angle of the two access spots!
