hendershot
Newbie
- Feb 14, 2005
- 25
I bought a 71 Bronco in all original form no mods. Been restoring it for year now and i'm at the point where stuff is finally going back together. The problem i'm having is that the front axle passenger side is 3/4 of an inch more forward than the other. At first I thought it was the bushings, so I reinstalled the arms to double check if parallel and c-bushings in correct sides, also checked to see if the arms were the same distance from the end of the radius arm to the back of the axle, then I checked the bushings on the frame mount both seated good and the big donut is still welded on the bracket. Then double checked that the axle is centerd (no problem there with the help of a rachet strap). Then i checked to see if the frame was bent (the body is off so no problem) it's only 1/8 off diagonally (which i believe is one frame rail is 1/16 forward) no big deal. So finally I decided to see if the radius arm mounts were the same on both sides, I measured fom the the center of the front leaf spring bolt to the back of the radius arm bracket at the 12 o'clock position it's a whole 5/8ths differant from sided to side! What the **** They don't looked modified rewelded twisted or anything. Is that the way they came from the factory? ANY HELP PLEASE
