I am putting a conversion kit into a dual point mallory, I used the mallory 700 ballast wired from my original coil wire ( not sure if there is a ballast wire in the loom on my 74? )
My question is : Where do I hook the red wire from the Distributor as I have read that it can go to the positive side of the coil. ( saw this on a video ) Although the instructions say to run the red wire to the 12v side of the ballast resistor...The wiring on the kit makes going to the coil clean, If I have to run it to the resistor then I would either cut and splice or figure out how to put the ballast resistor near the coil...uggghhh!
Attempting to do a clean wiring job and if the wire can go to the coil it would make things nice and easy.
