To properly spec out a master cylinder, we would really need to know what you're actually running in terms of brakes. Ford versus GM, standard versus oversized calipers, rear disc brake solution since that's clearly aftermarket, etc. Weirdly, Ford Bronco's are some of the few applications that received the same bore size master cylinder (Ø1") for both manual and power brake applications, drum/drum or disc/drum.
