Rebuilding my column (3 on the tree) and the tab on the shift tube looks decent (welds in place) but the hole has rounded out / opened up a bit. I’m 99% sure the play in my shifter was due to the shift collar hole also being rounded out (where the roll pin holds the handle on) and the broken/worn bushings between the shifter arms.
But, while I have this all apart, I’m not sure if there’s anything I can/should do to repair this hole? I hate to go through all this and still have sloppy shifts…. But also not sure what I can do about it. Any thoughts?
