Manual Steering Box Removal
Jncuts
I am trying to remove my manual steering box as well as the rest of the steering linkage. How do you get the linkage to come apart? I have tried a tie rod fork and have not been able to get the pieces apart. Is there a special tool that is required?
Any help or advice would be greatly appreciated.
englewoodcowboy
Lick Creek Restorations
Two large hammers, place the fork in to create some tension and take the 2 hammers and smack it at the same time on each side where the taped stud is.Sometimes helps to have an extra set of hands. They also make a puller you can get at tan auto parts store for pulling them apart.
Jncuts
Jncuts
I thought I might need a puller, always a fan of trying a bigger hammer.
Thanks for the help
Since my timing is not always right on the money with the 2-hammers method, I do what my dad used to do and just lay the one big hammer up along side the area you want to smack, then hit the opposite side with the other hammer.
Having the one laid up against the metal still creates the shock/distortion that you're looking for.
In fact, this can be done with a single hammer and some good whacks, but the pitman arm on the steering box is one of those things I don't like to hit too hard. I don't mind doing it on the knuckles to get the tie-rod off, but the pitman arm gets a little more finesse from me.
And when it comes time to remove the shaft from the gear box (if you haven't already) you will need to pull the cross bolt all the way out. Not just loosen it to relieve tension on the clamp. It sits in a channel and has to come out to let the "tulip joint" slide up the splines.
spray1963
Boca Raton,FL
Doesn't hurt to heat them up a little either. Then used the fork, puller, or hammers to persuade them to come loose. With the fork, if you think you are hitting it hard, get a bigger hammer!
tortoiseracer
Tempe
I tried all the hammer,heat,forks,and puller. Nothing worked. On one I finally had to cut a slot in the pitman arm, cry,cry to get it off. On another I had the puller on it after heating and penetrating oil and was about to give up, went back into the garage to cuss a little when I heard a violent pop, and that one came off. Think the bronco about lifted in the air. Tried the two hammer one on the one I had to cut, a ten pounder and a five pounder and finally gave up when metal started to mushroom. Of course this was on a 66 with the small stud. I have since bought a 20 ton press and am looking foreward to the next one, bwhaaaaaa.
Chris
