Manual to power steering question
Darryl M
Angie
I’m swapping my 69 Bronco 6 cyl over to a 302 and plan on installing a power steering kit. Will my stock steering shaft hook up to the new power steering box without modifications? Any advice is greatly appreciated TIA
Pa PITT
Stephenville TEXAS
I'm going to say ... NO NOT WITH OUT SOME MODIFICATION .
BUT I did my 72 so many years ago I've forgotten.
But seems to me like I Used my stock stering & cut it off added a ... CHROME U-JOINT ...
mY BRONCO is blacked out but has a chrome ujoint on it's steering . But it's under the hiid who cares .
.. But Im' sure I just moved one step at a time . & I just added the u-jOINT .
... I HAD MORE trouble getting all the part to mount the pump it's self.
..& The W/P Pulley had the wrong spacing between the belts .. Crank had them close together but the other pulley had them about 5/16 gap between the belts . But I found a correct pulley. I'm going to say don't expect to do it over a weekend & you'll be find .
mine took about 3 weeks to complete.
As said, no the stock shaft does not work without mods. A couple of them.
First it's one long piece, and it's too long. Second is that the interface, the "tulip joint" coupler uses a common 3/4" x 36 spline size, while most power steering boxes that are used today vary from that theme.
If you use a stock power steering box it's a 13/16" by 36 spline setup. Not far off, and it might work for awhile, but it's not really a good idea to mix and match that on such an important piece.
The new boxes are using some odd combinations, so it depends on the box. A "4x4x2" box is 3/4 x 36, but your shaft is still too long and the tulip-joint is too sloppy for most modern tastes.
We have a video on how to modify your existing steering shaft (click on the link here: https://www.wildhorses4x4.com/product/Custom_Lower_Steering_Shaft/Bronco_Steering_Shafts) so you can see what's involved.
You have 1 and a half choices. If you want, and if it works out, you can just modify the lower portion of your shaft and include a new u-joint. But in some cases that's not really a workable solution and for those you need to replace that long section of shaft with a more modern (and safe) collapsible shaft like in that link.
So it's totally workable. It's just not a bolt-n-go kind of thing. No plug-n-play in this case.
