broncoitis
- Jul 23, 2010
- 4,449
Ok, today something somewhat strange happened with the Bronco. I am getting ready to take it on a little road trip down to the shore and going down the street the truck sorta pops out the exhaust and completly stalls out. Start it back up and truck maybe goes 100 yards and stalls again. So I pull over on a side street and let it sit for a little bit and eventually give it a try and the truck starts momentarily and dies. This goes on for about 30 minutes and the truck still wont idle or run for more than 5 seconds before stalling out.
I run the codes and I get all the typical codes that are expected with the RJM harness. Eventually, I get the #11 code which means all is goood and there are no issues in the EFI as far as I know.
Prior to running the codes the check engine light was on and after running the codes the light went off. Also, after running the codes the truck started right up and seemed to run alot better and I was able to drive it home without getting towed. %)
Can any of you EFI experts possibly shed some/any light on what in the HELL happened tonight with the truck???? I really don't want this weird stuff to continue to happen. Thanks!
