Mass Air Sensor Options
00gyrhed
I am building a cold air intake for the bronco and want to use a flanged type Mass Air like the attached picture. Best I can tell they were on 94-95 Mustangs and then 96 and up on cetain models.
I will be using an A9P computer, as long as I get it calibrated for my injectors will there be any issues using it with the A9P that was only used to 93?
blazinchuck
Go toa pull yard and pull a MAF sensor off anything (including V6 and V8 vehicles) that has F2VF-12B579-A1A or A2A. i was able to get one off a crown vic...it came with a bolt on flange style like you pictured. plus its a 70mm and you should have to do anything with the computer. simple bolt on;D
EricLar80
I used the lightning MAF (LMAF) from a 2003. You can get various kits online that allow you to use this setup, but they are known to be very reliable at idle. This will be even more important on a smaller displacement engine.
However, you really should have a chip that corrects the program to the right curve if you are going to change the MAF in any case. Calibrated MAF's is a bit of a misnomer.
Good Luck,
Eric
00gyrhed
00gyrhed
I guess I should have mentioned right now I have a 71 302 with an 87 SD system. The conversion to MA is happening to support the new 393.
I need to upgrade my injectors and I would like to put in a 76mm or even 85mm MAF meter especially since they are the same price new, and I already have a hose (junkyard pull back when I had time) that will go from and 85mm MAF to my throttle body.
Once its all together its going to the tuner.
I wish I had time to go to wrecking yards and pull stuff but if I did I would never get finished with the project. I built this bronco real cheap with e-bay and wrecking yards anf this engine and transmission almost triple what I actually have in it. Partly because of the things I did but also due to the fact that the bronco was a really cheap build.
EricLar80
Oh, and to answer your earlier question - if you are getting a tune anyways, then you can pretty much put anything together. For me, the choices pretty much came down to whatever seemed to be reliable and within the operating conditions I planned to use them. This is the reason I went with only 30lb injectors.
Eric
So long as you are getting a tune, doesn't really matter what MAF is used. Find something with similer HP levels to what you will make. HP is pretty much directly related to airflow. Late 4.6 mustang, lightening trucks, etc.
