Max tire size
c-gallagher
I'm sure this has been asked before but I'm having trouble finding it. Whats the tallest tire you can run with a 3.5" sl and a 2" bl?
99f250jr
37's I would guess. I know the most you can go with just the 3.5" sl is 35's.
How big of a tire fits depends on how much has been cut to make room for it.
I have seen 33's fit with no lift and a little trimming, and 35's that took a LOT of lift to keep clear of the new paint job.
Add in how lowered the bumpstops are and there isn't a real solid number.
Devin
Bronco Kineticist
I have a 3.5" SL and a 2" BL and run 36"s with plenty of room. 37's would fit nicely. But, I also cut my fenders pretty high.
KyleQ
5.5" of lift + flexible suspension + 37's = lots of cutting.
ep67bro
Bronco Junky
Easton, MD
3.5" lift with 2" body 35 to 37 inch tires.But...... you have to have cut fenders and the right wheel backspacing or you may rub at full stuff.
KyleQ
This site has been getting bad as of late - same questions wasting bandwidth day in and day out.
JWMcCrary
You guys sure know how to throw out the welcome mat, geez.
This pic is with 3.5 suspension, 2 inch body lift, using WH warflares. The inner fenders have been trimmed and sharp edges smoothed out somewhat because every so often they will rub. Tires are 37" Iroks on 15x10 wheels using 1.25" spacers. Hope that helps.
c-gallagher
c-gallagher
Thanks for the info I really appreciate it. Great looking EB ^^
BIGED
Guru ????
Heres 3.5 susp 2 body lift with 37x14.5 on 10 in wheels with 1.5 wheel spacers also cut high and inner fenders smoothed of sharp edges
stock1970
Olathe, Kansas
keep in mind the gears you are running .. but 37s will fit .. with lots of trimming, 35s with some trimming and 33s with a little bit of trimming.. lol..
luderchris
SouthEast PA
4.5" susp, 2" body lift
38.5 x 14.5 Swamper TSLs
Works great. Room for 39.5s in the future.
