Maximum 9-inch pinion angle while still getting gearoil?
dingo8
Luzerne County, PA
I know that the more you rotate an axle, the less oil your pinion bearings receive, right?
Well, assuming that if the pinion centerline - if totally horizontal - is zero degrees... what's the maximum you can rotate the axle and still receive healthy oil supply to the pinion bearings?
Madgyver
Bronco Madman
I was concerned about this also but as the diff spins, oil will be all over in there.
How much should I move the spring perches for a 5.5" lift with national 11 leaf packs? Roughly
