MAXIMUM wheel offset
bigjhoov
nobody
Sorry guys, I've searched but can't find a difinitive answer. What's the maximum offset I can run with 15x8 wheels, drum brakes, and a dana 30? All of the steel wheels I'm looking at have a 4" offset.
broncnaz
I have no idea what the maximum offset is. kinda depends on the wheel manufacturer. What exactly are you looking for most wheels are availible in different offsets just have to be special ordered. I'm running 15x8's white wagon wheels with 3 1/2 back spacing.
mp
Austin, TX
A lot depends on what size tire you are running. I have a 1969, with Dana 30, drums, and steel 15x8 with 4.5 of backspacing. At full turn, the tires rub on the radius aram, but I have 33x12.5's on them.
bigjhoov
bigjhoov
nobody
I'm looking at running a 33X10.5. The wheels are the black rockcrawler type available through many different manufacturers.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
I'm thinking it's 3-7/8" for '66-'75, & 3-5/8" for '76-'77. Or maybe that's just the factory offsets, or it could be both.
It's the tie rod ends that determine the max offset for a 15'' dia wheel. Wheel width & tire size can affect when the tires rub the radius arm but they don't limit the offset.
mp
Austin, TX
I have those same rims with 4.5 inches of backspace. You should be good to go with a 10 inch wide tire, and your combination.
broncnaz
I have same rims just in white with 3 1/2 or 3 5/8 back space I cant remember exactly I'm also running 33x10.50's with no rubbing any where.
broncosport
Knob Noster MO
rims
If you are trying to get more clearance I,ve seen a few rigs with 15x8 Rockcrawlers and 2.5" of back space and they seemed to work great, the one guy was running 36x12.50 TSLs and with a slight stearing stop adjustment they didnt hit the radius arms.
