Mazda 5 speed trans
Crewwzin
Freeport, Fl
Does anyone know if the output shaft on the M5R2 is the same as the ZF? I've looked and looked but cant find any definative answers. My reasoning is that I would like to use the AA ZF adapter kit to the D20, but I dont want to spend $400 and it not work.
Crewwzin
Freeport, Fl
FedEx is FASSST!!!
Got my M5R2 tranny off the truck today. I must say, I'm quite pleased with the deal. I've opened it up and it looks great. It's a little dirty on the outside but I expected that. Inside, clean as a whistle. Now I just gotta get it hooked up and put in. Wish me luck.
For you guys who look inside of a lot more transmissions than I do, take a look at the pics and tell me what you think. Did I do okay for $375 to the door?
DonsBolt
Chestnut Hill, Mass
I don't know if anyone has heard this, but with NV3550's getting harder to find Advance Adaptors is now making a kit to put AX 15 transmissions in the EB now.
Just figured I would let you know there is a new alternative out now
Potshot
Inglis, Florida
That's good news... anyone know what xfer cases mount to this natively?
Actually it's good to hear about the Mazda option too.
Crewwzin
Freeport, Fl
I've heard the AX15 is poop. Thats why they replaced it with the 3550. I dont know, I personally just like using something that came out of a Ford vehicle from the factory. That, and I cant justify buying the extra adapters for the trans to engine.
needabronco
Prescott/Farmington
AX15 are generally junk, they couldn't hold up to the measly 4.0, not to mention a 302 or a 351.
At least they are fairly plentiful and cheap, I guess you could buy several and have a spare....
Crewwzin
Freeport, Fl
Had to dig this one back up for an update on progress. Being as how the ZF is a direct bolt in replacement for the M5R2, I naturally assumed that all of the other parts would work as well...ie, BC's crossmember, all the hydraulic clutch stuff, and the AA ZF adapter. Well, I'll be damned, I was right. I got the crossmember in this past weekend and I'll be working on mounting the transfer case next weekend. The shifter even comes up in the same place!
Here are some pics for the pic whores, um...er....pic lovers.;D
Tito
CB Fire Starter
Bakersfield, CA
Looks good bud, that 3" BL sure helps to get it in there and not have the shifter in the dash (still have to reweld mine some more). Good choice on the zf, I'll put one in my next Bronco too.
Crewwzin
Freeport, Fl
Yeah, I should've went with something slightly bigger than a 1", but I didnt want the look of a bigger body lift. It fits fine because the M5R2 doesnt have the "girth" ;D of the ZF, but the rest of the dimensions are the same.
I think it'll work out just fine for what I plan on doing with it. But I cant help but wonder, am I the first to do this swap?
Bronco73
Bronco73
Cape Coral, FL
I would say you are the first to do this swap. I had checked into this more than a year ago and every one was against it and said to go the ZF route.
Now it's time to start putting together your very own tech article on this swap.
You have a 1 inch body lift? I have a 4x4 mazda trans sitting in the garage that I plan on installing into an EB if I ever get one. Working on that little problem this week.
Great job and let us know how the hyd clutch set up works out for ya and how it drives. I will follow the thread with great interest. Now the cheap priced mazda trannys are going to go up in value.
Tito
CB Fire Starter
Bakersfield, CA
Ah, I need to read a little better. I thought that was the zf. Cool its the mazda, looking forward to hearing how it works for you. Did you go down to a 1" BL, your sig says 3" thats why I thought you had 3". I used a 1" with my zf.
TuffBronco
AZ Desert
That's awesome! I as well was surprissed when I did a little searching to see that nobody seemed to have done this swap and or recomend it. Sometimes there is only one way to know, to try it.
Look forward to further updates. This would be cool in a tech how to thread.
Crewwzin
Freeport, Fl
Naw, its a 3" suspension lift. I went with the integrated 1" body lift and urethane bushing kit from Wild Horses. Definately necessary...wouldve never fit right without it. I hope to get the hydraulic system tied in next weekend as well.
By the way, the junkyard is the way to go when buying master cylinders. I got the master cylinder and the hose for $20! I'll get to work on putting together a thread for this swap, but to be honest with ya, so far it seems to be verbatim for the ZF threads. Except with a Mazda tranny and not the ZF. Stay posted though.
akforsyth
Well I gotta admit, I've been waiting to see how this was going to go before I made my choice. With those tranny's being a dime a dozen around here I think I will definately try one in mne now that I am not the first guinea pig. Thanks Crewzin, looks great...
fordtrucks4ever
DFW
If possible, can someone get a measurement from front of bellhousing back to center of shifter?????? I have a different tranny and want to get an idea of where it will actually come thru the tunnel.
fordtrucksrule
my zf only costed me 480 to my door used in great shape hehe
Bronco73
Bronco73
Cape Coral, FL
The shifter maybe in the same location as the ZF but they both mount differently and the handles will not swap between each other.
Since my mazda trans is sitting on the floor i will measure it tomorrow, hope i don't forget.
I paid $200 for my mazda trans and it's a different one than one I originaly started the thread about. With hardly looking for a trans i found two of them with in a few months. Every ZF I found back in Ohio was as cheap or cheaper than what I had paid for this Mazda trans but I had the connections there and nothing here in FL.
The thread makes me want to go outside and clean up the trans and i don't even have an EB yet.
Bronco73
Bronco73
Cape Coral, FL
From the bell housing mounting surface to the center of the shifter is 13.75. If you need the over all length, it's 29 inches.
