Mazda 5 speed trans
Dave
The car cover may fit the truck version of the trans but in the pictures you can clearly see that where the car shifter sits which is part of the tail shaft is where the 4x4 ext. sits so there is no way to use the car shifter set up on a 4x4 trans only a 4x2.
Bumber! It would pop up right next to the stock position of the t-case shifter.
snoranger
New Jersey
The m5od isn't a bad trans. You just have to replace the 3 rubber plugs on the back of the shifter plate w/ metal plugs. The plugs tends to leak all the fluid out slowly and then burn up the trans.
If you want to move the shifter back on a 4x4 m5od R-2 you need a 97+ 4.2l trans. Thats got the shifter a few inches back from the earlier location, and uses the same bolt pattern as the v-8. If you already have the older trans You can swap the newer shifter plate on.
As far as strength, you should have no problems with a mostly onroad truck. I have 3 vehicles with this trans, and they all shift smooth and hold up to a beating. (94 explorer w/ 35's, 89 T-bird Supercoupe, 92 Ranger 2.3l)
Bronco73
Bronco73
Cape Coral, FL
Was the 4.2 first introduced in 97 and how long was it offered? I would guess that the shifter is still mounted in the cover/mounting plate and not in the tail housing? Does the 4.2 trans had the same input shaft as the older versions? Same flywheel dia.?
snoranger
New Jersey
From what I've seen the m5od 4.2l combo was used from 97 to 04.(maybe later, i dont know for sure.)
Yes the shifter is still mounted in top plate but is at the very back of the plate, not the center.
I dont know what you have but a 1-1/16 x 10 spline clutch and 164 tooth flywheel were used on the 4.2l. The 4.2/3.8 uses the SBF bolt pattern so it will bolt up to the 300, 302, and 351W.
Cooter_76
That looks like the same Mazda 5-speed I had behind a 300 inline 6 in an '89 F-150. It held up well to a lot of abuse (high school shenanigans + towing farm implements, hay, etc weighing far more than the truck was rated for.) I replaced the clutch once at about 130K miles and it was still running strong when I sold it at 195K on the original slave cylinder.
What made it a poor truck transmission IMHO was the lack of a low first gear.
Gud Racing
I am working on #5 in my DD ranger. I do work it hard but they seem to have a input bearing issue.
evil69
fawkin classy
Athens, GA
I have went through three in less than a year in my power ranger. 4.0 4 wheel. Yes I drive it like it is stolen. It is not running dry or leaking. The thing is just coming to pieces. Although I can swap the thing out pretty quick now.
Itsa67
Isn't the Ranger tranny the M5r1? If so then it is a lighter duty tranny then the M5r2 that the newer full sizes came equipt with. Oh, the tranny in my ranger is garbage too...it whines so loud I can't believe its still holding together. :)
Bronco73
Bronco73
Cape Coral, FL
I believe it is and this would be why the full size mazda trans gets a bad rap.
byson1
Nashville
The 1/2 ton trucks get a HD version of this tranny so what's floating around in Rangers and pre 96 Explorers are not the same. There is not anything wrong with this transmisson. I'm driving well used one with over 200k miles and know of many more high mileage one's that are holding up fine. Is it as strong as a T18, NP435, NV4500, ZF etc....NO But it's not as heavy and provides a good streetable 1st gear and overdrive and will hold up just fine for mild off roading.
Correct. Can't lump all Mazda transmissions together. A friend got one out of a supercoupe a while back. was going to stick it in a mustang to replace the T5. Had the top cover off both transmissions. The Mazda has some nice big gears in it. Not as big as T18/NP435, but still big. Then again the 435/T18 also were ofered behind big blocks and diesels, so there is plenty of heavy duty in them. The only bad things I hear about are the plug falling out and draining the oil and the expense of the rebuild after that happens.
Crewwzin
Freeport, Fl
Had to drag this one back up. I just purchased a M5R2 and as soon as I get around to getting it all put in, I'll write up an article with plenty of pictures. Wish me luck.
TuffBronco
AZ Desert
Sounds great, and good luck. Look forward to seeing it. I've heard the M5R2s can in reality take some pretty serious abuse if kept full of oil.
grant_71
Glad to see this brought back up, i have one that will be going in this winter, i don't want my truck down as long as it will take me to do it in the few short months of summer we have here in Northern MI. I paid $100 for the transmission, and just to be safe it will be rebuilt before it goes in.
We have the same tranny in our 92 FSB, and it has 175k on it with no problems at all, and it has lead a hard life towing and some off roading on 31's. So in an EB with less weight, with minimal towing and very little off roading, i see no problems at all.
orange69
I had one in my old 91 F150. I had a small lift and 33's. I had to replace the tranny after 80 some thousand miles. The technician said they are not very good tranny's. The imput and output bearings go out very easily. He said that whining noise in third and fifth gear and quiet in 4th was because the imput/output bearings were toast. He worked on them all the time. After I totally replaced the tranny, the same noizes came back-whining in third and fifth only after a few thousand miles. Maybe it was bad luck, but I would stay clear of them. Nothing ever "broke" just started sounding like it would explode. He also mentioned those stupid little plugs that fall out or leak was the culprit most of the time. I would hold off for a ZF. IMO.
Crewwzin
Freeport, Fl
If I EVER put 80K on this Bronco, it'll be a miracle. I've heard of the same problems and at this point, I just gotta get the thing put back together. The transmission is the biggest piece of the puzzle and I have held out for 6 months for a ZF and still cant find one at a reasonable price. I'm gonna go ahead and be the guinea pig and maybe, just maybe, the Bronco world will have another option for late model 5-speeds after all.
Bronco73
Bronco73
Cape Coral, FL
I passed on the trans that was local to me and I should have bought it. If the seller would have come down a bit I would have owned. Plus the fact that I still haven't sold my car so no EB yet.
As I mentioned before my father has 300K plus on his mazda trans. If you abuse it, then it will fail but for a DD, I think it will be an EB owners best option.
