Exciting times measuring for new driveshafts...that means it's sitting at ride height for the first time in 6 years!
I'm sure it's been asked before but I could't find it.
When you measure for your driveshaft, everything I've read says measure from flat to flat on the yokes but what if they aren't parallel? The top flats are farther away than the bottom flats so which measurement do I go with?
I assume it's the bottom so do I just go with the minimum dimension?
Last question, anyone running drive flanges instead of yokes on your T-case? Looking for opinions on them, advantages vs disadvantages. I know they are stronger but do they limit anything? I have high pinions front and rear so angles aren't much of an issue but I am running a good amount of power. Any input is appreciated.
Jon
Jon
