I am in the process of adding a new cam, aluminum heads, and roller rockers to my 351 F4TE block. I have watched so many youtube videos on measuring for the correct length pushrods, I'm pretty sure I have this correct but just wanted to ask here for peace of mind.
I measured these two different ways based on the videos I watched. One was by marking the valve tip with a dry erase marker and then adjusting my adjustable push rod to the point where the wear mark was centered on the valve when the lash was set correctly. The second way was getting the rocker to a 90 degree angle to the valve, calculating 1/2 of gross cam lift, and then tightening the rocker appropriately before once again using the adjustable push rod.
Both of these gave me push rod lengths within .05 of each other, so they came out remarkably similar.
My one concern is taking lifter pump up into account. None of the videos mention any difference between measuring the length on a dry engine vs. one that has had the lifters pumped up. My concern is with the lifters pumped up the pushrods will now be too long and possibly cause damage.
I have attached photos of my #1 cylinder with the engine at top dead center.
Any expert advice or comments here?
