DuctTape
Have a 71 that I'm finally getting to working on. Ran across http://classicbroncos.com/forums/showthread.php?p=1109751#post1109751, which states that the stock distance between top of axle tube and bottom of frame is 7" for front and 6" for rear.
Just ran out and measured - I'm showing 9 1/4" in front and 10 1/4" in rear, yet the bronco doesn't seem to have a strong forward lean when viewed from the side.
Is it possible the OP means 6" for front and 7" for rear? Or did my PO really screw things up? I'm about to order some new steering components and I want to make sure I have the lift figured correctly before I buy.
Thanks in advance for the help!
