Mickey thompson wheels
markatherton
Anyone know if MT 15x8 with 3.6 inch backspacing will clear 76 77 disc brake setup?
904Bronco
San Martin, CA
I know that the US mags 15x7 with 3.75 BS required a 1/8 wheel shim to clear the tie rod end on my 76 housing.
But, I cannot answer your question directly...
Baer brakes made the steel shim and I had to have the center hole opened up to fit the hub.
I'm drawing a blank again Mark, but don't we always say that up to 3 5/8" will work with those knuckles? If so, then 3.6 is just below that (3.625" = 3 5/8") and "should" work.
But then you're so close you're getting into the area of worrying about how thick the cross-section of the forging is in that area.
I think I heard just recently here where someone with 3 5/8" bs wheels actually hit, while most don't.
I know that does not answer the question for sure either, but I think you're pretty close to working at that point.
Any chance you can get one locally and trial fit it? Or do they have to be ordered?
SHX669
Anybody????
If you can find out what the backspacing is for MT Classic II fake beadlocks 15x10s - 5 x5.5 { I don't remember and couldn't find it } then this might help.
These wheels on our '76 required 1/4 spacers to clear the tie rod ends.
Justafordguy
X2, I have the 15 x 10s on my 77 and had to use a 1/4" spacer as well. The website says 3.63 backspace for the 15x10 wheel.
