LouisT
So I've looked behind the starter and found casting ID of ETZ which looks to mean the engine is an '86 truck motor. My Bronco is a '70 and the PO says he changed out the engine using on of the more famous Bronco shops here in Texas. I've quizzed them and they were very helpful but there are gaps left unanswered. The PO (he sold the truck to the Bronco shop before all the final work was completed) remembers the engine being an '80s engine. Long story short, I was changing out the distributor and found the firing order is that of 351W or a 302HO. It's known now that the engine is most certainly a 302 and looks to be an '86 from a truck. SO maybe it has a 351W cam installed or did Ford begin using the 351W firing order on all mid '80s 302s? In George Reid's books on Ford Small Block Interchange, he says ALL 302s went to the 351W firing order in the "80s. But, if you look on the inner web, there seems there were two 302s then. One an HO and one regular and they had different firing orders. Any ideas?
