- Jun 4, 2002
- 35,059
I really feel the 220V is the way to go. But if you can't do that I would look at one of the name brand invertor based machines (as opposed tot he old school transformer). Being more efficient you should be able to get more out of a 110V power source. And many are duel voltage and can take 220V if available.
Before you go too far into the 110V route, how good are the outlets in the garage? How much run is there between the panel and the garage? is it done in 12 or 14 gauge? If you have a single 50' run of 14 gauge wire running everything in the garage you are out of luck anyway. You will have voltage drops every trigger pull, lights dimming, you will never get a good weld regardless of how good of a welder you get. If you have a fairly short 12 gauge (20 amp) service, especially a dedicated outlet, then a 110V welder will work fine. The point is if you need better power in the garage to run any welder, you might as well do it in 220V.
