mig welding body panels
saggin'71
Farmersville
I'm about to start welding new steel (rockers, posts, kick panels, floors...). I've always used flux cored wire for my barn projects (not very pretty) but I am wondering if I need to use gas and what size wire. Any thoughts are apprciated.
S
saggin'71
Farmersville
Thanks. I'm going to pick up the needed equipment now. When I get smart enough to post pictures of the mess I have, I'll do it. My friends think I've lost my mind (they've seen it) and to quote my wife, "Are you going to be able to put that thing back together?" My typical reply "Of course." I have concerns...
Justafordguy
Don't worry, I've seen some sad Broncos brought back from the dead (including mine). Just stick with it and ask here if you run into any questions.
Oh yeah, welcome to the site.;D
Crawdad
Good wire of choice above. Just remember to spread out your spot welding. Even better to jump back and forth on panels. Let us know exactly what you get, gas too. What kind of MIG machine do you have? Good luck on ur adventure, I will be watching closely b/c I will be doing the same thing!
S
saggin'71
Farmersville
Thanks. I'll keep y'all posted and appreciate the input. This forum is probably the best thing I've done for my tired horse.
nelson_bros
los anchorage
Here is a good article regarding the typical spot-welding method compared to continuous-bead welding from Ron Covell. It brought some interesting thoughts to light for me, and although I haven't had a chance to try it (nor would my welding necessarily improve from typical seagull poop welds) but it does make sense.
http://www.streetrodderweb.com/tech/0802sr_skip_welding_vs_continuous_welding_seams/index.html
I subscribe to Street Rodder and in the Sept '11 issue (Professor Hammer) Ron talks about spot welding 2-3 inches apart, then welding continuous between two spot welds, and then hammering on-dolly while the weld is still hot to help minimize distortion, since it is most effective to remove the distortion in the order it happens to the panel. He makes the point that it is not necessarily a better method, just a different one that tends to result in less metal work later as well as less body filler - not always critical with our trucks for sure.
Good luck on your project and just keep picking away at it, eventually you'll be back on the road!
jarrod
Bronchole
Chatsworth, Ca (LA)
When you blow holes in the sheet metal, take a piece of copper pipe, pound it flat and use it to back up the weld area. The weld won't stick to the copper. A brass block will work also.
Be careful, they get pretty hot ;)
