winston vizsla
I just installed new mile marker supreme hubs in my '73 bronco tonight. My problem is the inner snap ring doesn't fit, only the outer C ring. My brother and I were able to use a pry bar behind the u-joint and finagle the shaft out enough to get the snap ring over the axle shaft. The problem? It's so tight that when you screw the caps back on it nothing spins.
In the instruction manual it actually says that the inner snap ring won't fit on some older model vehicles and that's it fine but it just seems weird to me. Has anyone else had/seen/heard of this issue?
