Missing front body mount?
DC_Gearhead
So I'm in the process of replacing my body mounts and adding a 2" body lift to give my 351w some room to breath and me some room to work around it. I got to the front mounts and they appear to be gone. The frame side is there but they don't have anything to sit on them. Driver side has nothing and the pass side has a DIY tab bolted to the body mount.
I don't have a Bronco to look, but typically the front body mounts hold up the radiator support...or they hold up SOMETHING. It looks like I am missing something here. Can you guys take a look and give advice? Pics wold be very helpful.
Below is a pic looking down on my pass side forward BM.
Viperwolf1
electron whisperer
It's somewhat common for that mount under the battery to fall apart. Acid from the battery runs down there. I believe JBG has new ones.
DC_Gearhead
DC_Gearhead
Is this the piece? If so, should I install it to have the flat part flush with the bottom of the radiator core support panel?
Viperwolf1
electron whisperer
That's it. The 2 vertical strips are spot welded to the core support and the angled end is spot welded to the inner fender. Someone else will have to answer on the height.
DC_Gearhead
DC_Gearhead
Thanks man. I was wondering what that angled flap was used for.
Hopefully someone will chime in about the height.
suckerpunched
If it was mine, I would go with this approach, clean up that area, you will have to remove what is left of the old piece. you might find more rust to fix while your at it.
get all new body mounts and your 2" spacers in place and tightened down. Bolt the new tabs down to frame with body mounts and spacers installed. check you body alignment. door to quarter panel and front fender to door. If it all looks good, weld the new front tabs to the core support.
No actually if it was mine I would completely blow the entire truck apart on the shop floor, strip it down to bare metal fix all the rust. Then let it sit there for about ten years before putting it back together.
DC_Gearhead
DC_Gearhead
I've tried your second suggestion. That one didn't work well for me. I have a 70 Challenger still waiting in the 10 year sitting period. At this point your first suggestion seems a little better for my situation. hahaha.
I was going down the same path, but I had a concern that stopped me. That would work fine if I were confident the Bronco was pretty straight. The tub is straight, but both of my inner fenders are rusted through back by the firewall. The pass side has a pretty good dent in the grill that warped the fender, so I know that side is not aligned and good. On the driver side the inner fender is rusted through at the same spot and my inner wheel well is radiused for a huge power steering gear. Over half of the well is cut out. Basically I am not confident the radiator core panel is supported at the correct height in relation to the tub. Too many factors that could are probably do affect it.
Since I am going to start doing sheet metal work in the front, I would love to set the radiator core piece perfect on the body mounts and built to it with the sheet metal I am going to replace. Then I would know it is straight and aligned.
I'm still hoping someone can send me a picture or measurement of that plate in relationship to their core support panel.
DC_Gearhead
DC_Gearhead
OK, I got my answer. It flushes to the bottom of the core support bracket and sits on the bottom lip of the radiator support.
jmangi62
I had to do this repair,and I think you're good to go,I fit mine the best I could to the core support,I added extra supports on the drivers side to mount a dual battery tray,worked out sweet,although I will say I lost a lot of real estate doing this mod,but well worth it,I'm running all kinds of lighting,stereo,winch etc.Good luck.Jim :cool:
