Mock-Up Is Complete!
Tedster100
Chairman of the Bored
Finally got all the body parts to fit together. All fiberglass except the windshield. The tub, doors, tailgate and grill are all from different manufacturers so making them fit was a real chore.
I cut & shaved the fiberglass doors to accept the rails for the soft removable windows and installed the top to check the fit. Fits better than expected! All the weatherstriping lines up and compresses perfect.
Just have to do the final body work and prep for paint, finally there is a light at the end of the tunnel!
Heus33
Lookin good! Curious how you like the fiberglass doors. How bout a little more info?
Tedster100
Tedster100
I bought the doors off ebay about 4 years ago while collecting parts for the build. I have no idea who built them or what brand they are. They are pretty well built but when I mounted them I found they were out of whack or twisted so that the bottom side at the back of the door stuck out about 1/2" from the body. Everything else fit great. I was not happy about the fit until I decided to just cut the outer shell loose from the inner shell and remove enough material to let the outer shell sit flush with the body. I installed a brace and screw in the panel to hold it in place then re-glassed from the inside and touched up the cut to fill it in. Worked perfect, door slams shut solid and with a nice fit.
Upper doors are from Bronco Design and his Canadian pal. Very pleased with the quality. Came with the frames to drop into a standard steel door that is set up with removable frames but since mine didn't have frames I had to cut the top of the doors and drop them in. They bolt through the front and back side of the doors like removable frames but I glassed them in from the bottom and will be finishing them smooth with the tops of the doors. When I remove the windows the tops of the doors will look smooth just like the bed rails except for the two 5/16" holes to accept the frames.
Fiberglass is a real pain to get to fit and to finish but living in N.E. Ohio with the winters we get I wanted to rust proof the rig as much as possible. Everything I could make or get in stainless or aluminium I did so that it won't rot. Notice the stop sign cut in half in the background.. there are several signs in the build. Made for great firewall mounting covers, door latch mounting plates, etc...
Tedster100
Tedster100
looks good! i really like the look of the rear fender flares!
Kentrol circa 1995. Bought this rig in 1990 and my Dad and I have been working on and off since then. Got serious last summer and it's almost finished!
Tedster100
Tedster100
Here's a few more pictures. Engine witout front clip, hand made shifter for NP435 along with shift knobs I made. Harley shifter is a challenge coin mounted into a aluminium knob I spun on the lathe. And my axle wrap brace made from a top link from tractor supply and some 2" square tube.
azinny
Wellesley
i have the same problem with my doors on a fiberglass body. wish u were closer. would like to get a better look at what u did so that i can do the same to mine.
bknbronco
North Metro, MN
You got a nice glass bronco also. My doors are steel and the drivers side at the top rear sticks out about 1/4". I will have to add some material to the tub some day or maybe a different door will fit better. I love working with the glass, its easyer than the steel i think. The biggest problems i have run into is that all the aftermarket parts are a terrible fit no matter if there glass or steel. I guess thats broncoing for ya! I love all your custom touches. Mines pretty simple for now, i have to watch how much money i blow on my build!
I might be further along with my paint but your way ahead of me on everything else. I started in august and got the body first week of september. I still dont have exhaust, shocks, driveshafts. I also have to get a roll cage and soft top someday. Im hoping to start mine and drive it around the block before halloween! I rebuilt the motor myself almost 12 years ago so im not sure that will even run!
I need to get back to kentrol for some of there old glass doors. Im trying to get them to sell me a pair of old, used doors that i can cut up and make snoop doors out of.
I hope your having as much fun as i am building that glass bronco. It can be a headach sometimes but its all pretty simple stuff. Good luck!!!!
lowbush
Summerland Key, FL
I have to agree with you, while I am good with a TIG, metal just takes more time, especially if you have to shape it with anything other than straight bends. I have butchered a lot of metal on an English wheel. And with composites like Carbon Fiber and Kevlar that you can add to the mix, there are a lot of advantages to going to glass. As for the fit up, I kept mine simple, I have the old tub with the molded in tailgate. I hated it at first but I ended up deciding to run a floor bar in the rear, for my cage so it is going to be useless anyways, as my rear seats will be permanently mounted. I went with inserts for the doors, and I went with a one piece front clip. It made lining everything up a lot easier, because it took the doors and tailgate out of the equation, which is the hardest parts. That being said I think if I ever do another Bronco (which would be glass/carbon fiber) I would get all the parts from the same vendor.
Tedster100
Tedster100
I would think about talking to BroncoDesign, I think he has pretty nice glass doors. I bought the soft upper doors and one of his hoods. The best hood I have seen by far. I had a friend over to help with fitting up the hood and he could not believe how nice it was laid up. It has a couple waves along the sides right at the edge but those will block out with a bit of polyester filler. Otherwise it's totally smooth and clean and the inside is another panel that is epoxy'd in place. It looks as smooth, straight and clean on the inside as it does the outside.
It has been a fun build, I just hate body work!!! I would much rather work on the motor or fabricate parts and paint them than work with getting the body ready for paint. One of those things that I can do pretty well but I really can't do it fast and I'm sometimes too picky.
One of these days I'm going to put together a post on the entire build with all the pictures but to make a long story short I bought this thing for $300 in 1990. I ran out of time and money so I gave it to my dad. He pulled it apart and had a friend of ours re-build the motor in 1993 and he bought the glass body. It sat in his barn until about 5 years ago when they moved into a smaller house. So I gave him what he had in it and brought it home. I was building a Harley at the time so it sat for a few years and I really got serious last summer. The motor really worried me, it had been sitting for over 17 years without being started after the re-build. I poured oil in the cylinders and rolled it over once in a while for a month before I got it to where it would run. Fired right up and runs great! So this build is on year 21 without ever being on the road! I'm hoping to paint it in the next two weeks, then I can put it together for the last time!
