Suspension mock up need grease?
joshua
I’m mocking everything up on the frame for suspension and drivetrain before I paint the frame. Need to weld a few more suspension pieces on.
My question is, I’m at the c bushings and I’m wondering do I need to grease the c bushings and torque everything down? I’m just trying to figure out shock placement and making sure I have all the pieces to complete the frame, suspension and drivetrain portion of my bronco.
nvrstuk
PNW
Yes, can't remember the name but I use a specialty grease made specifically for polyurethane. SUPER-sticky lube.
Look on line, it works
joshua
joshua
So even for just mockup I should grease it up. Everything is coming back apart to paint. I kinda of thought that. But was just making sure
toddz69
I think grease would be very beneficial for putting the front end together, even though it's coming apart.
I like Super Lube - I'm convinced it's what all the suspension manufacturers put in their little installation tubes and tubs and mark up accordingly.
Todd Z.
nvrstuk
PNW
OMG, I would have blindly gone down the same rabbit hole!! lol
joshua
joshua
If I didn’t before, there’s no way now that I don’t have an FBI profile. Thanks nvrstuk!
nvrstuk
PNW
I get guys in trouble all the time, but usually not like this LOL
joshua
joshua
I was looking through my lube collection, is this it?
You don’t happen to still have the old rubber bushings laying around by any chance, do you? If not, and you happen to have a little time, you can get a new set for pretty cheap and use them for your mock up.
That way, no lubrication necessary, and you can put things together and take it apart multiple times without deforming the bushings.
Polyurethane bushings like to squeeze out and get “pushed” so to speak. Doesn’t make them useless after one run, but it does affect them.
Hence the almost universal agreement about using lubrication of some kind on them before installing.
And by all means, if you are coating the pads where the c-bushings go, don’t use the thick powder coat or POR15 kind of product. The tolerances are so tight, the extra few thousandths of material just makes the bushings that much harder to install, and that much more prone to deformation.
joshua
joshua
I think j do have them. Thanks!
