Thanks - it's been some time since I updated this thread, a few things have happened.
I figured out why the truck didn't have much power until I advanced the timing, which killed my hard starting capabilities. There was a 12V crank only power wire that I hooked to constant power as I was running out of time, and well, it started and ran, so I forgot about it.
Well it turns out that retards the timing while cranking, makingit easier to start. So this whole time I had been advancing the timing when the ECU was retarding it - no bueno. I put that wire on 12v start and bumped up the timing and WOW - lots more power and it starts much easier.
I did some shock measuring last night - my Dad's new rig conviently worked as an RTI ramp too
With the front tires hanging I have 11" of shock showing -
With the truck twisted up to around 95% capacity I've got the same exact 11" showing - so I'm not limited by the shocks as I've got ~3" of shock travel left.
As for the rears - I've got some superduty shocks laying around and mounting them off the factory mount and putting tabs on top of the old leaf spring pads I will only slightly limit travel - I might loose a half inch of travel in either direction, big deal. I've never lifted a tire anyway...
Last weekend I noticed I was about to loose a u-joint cap, so I took everything apart, cleaned and rebuilt the joint, ground the shafts for full circle snap rings and then tack welded each cap in four places to ensure nothing comes apart again. I've already killed a stub shaft and as soon as I get a wrap bar on the truck I fear that I'l start exploding parts again...
The Bronco/Pickup flatbed was a sweet buy - it has a 400 with ~20hrs on it topped with a nice Edelbrock intake and carb. The D44/9" combo has a L/S up front and a full spoll and Moser axles out back - 4.56 gears and 35" tires that are tubed. Full hydro steering and a fuel cell (installed last night) make this one hell of a ride. Now fi he can just keep this one shiny side up...
