Well I got the Bronco out and did some playing in the back yard - I'm having problems with my alt not charging and I've clearly got a bad vibration. I noticed it immediatly after the swap - either something is wrong or out of balance as I'm not comfortable with the vibration. I'm wondering if the harmonic balancer is shot or the flywheel is on wrong or what... odd.
Well after killing the battery and getting stuck I had to park it where it sat over night -
I came back with another battery and got it running and gave it hell, I was having fun digging holes and getting used to the clutch. Then I got stuck...
I was getting on it pretty good when I heard a snap - I knew it wasn't good. I shut everything down and took a peek at the driver's side, where I could clearly tell the noise came from. I looked at the joints and everything was in tact, so I figured it was a lockout by the little noise it made. I tried spinning the lockout but it didn't want to turn, and then it broke and just started spinning, I didn't think of it as the hub was probably fried in the process anyway. I got my 1 ton, that is FULLY loaded with steel, and got my strap - I needed to get the truck on flat ground to work on.
I got the Bronco out of it's spot (diff, radius arms, rocker panels, leaf springs and rear drive shaft all firmly planed on the ground) and noticed immediately that the tire was locking up... I popped off the hub, removed the snap rings and pulled out the hub, well, more then the hub came with it...
The shaft was toast - I got a few pieces out of it and tried moving the truck, it spun freely and I limed it up to the garage. I whipped everything apart and the lockout nuts didn't seem to come off as easily as I would have liked, and the hub needed some prying to get off. There was some nasty rust in there, but I fear the worst, I think the spindle took some damage. After I clean everything up I'll take some measurements, but I'm not confident so far...
The spindle bearings are trashed, my wheel bearings are pitted beyond what I would like to run and I should really by upgrading to 35 spine outers at this point... My motor is ready though - so that gets the cash first... which will undoubtedly lead to more broken parts.
