KyleQ
- Apr 24, 2008
- 5,480
I ended up bailing on the new power steering setup as I ran out of time. The trip went well and nothing broke. My throttle cable came apart a few times and after the trip I put a helper spring on the throttle body and ended up super-gluing the cable into the end to keep it together. Not the ideal situation, but it is what I had to do.
Flexed on the ramp with my buddies truggy-
I had my son in there so I wasn't pushing it, but his wheelbase and fancy linked suspension sure works well.
The next event was Dresser and it was basically a test and tune for the long 5 day trip into the Iron Range. We had a housewarming party for a friend the same day, so it was a short afternoon.
Matt's luck with power steering pumps was still not with him and he blew up one not ten minutes into the trail.
That same trail ride toasted a front R&P in the Samurai of the group and I lost an ignition coil in the middle of a water hole that I crept into.
What I didn't notice at the time was that I had a ripped off spark plug wire on cylinder 4 that caused the coil to arc to ground and eventually kill it. You can see the boot on the plug but no wire running to it in this picture. This is after I swapped coils on the trail - truck sure did great for 7 cylinders. ;D
I washed the truck on the trailer and noticed something...
