KyleQ
- Apr 24, 2008
- 5,480
My first outing went well, but the steering needed some work - my main concerns were I was starving the pump and I noticed the fluid was getting HOT. I came to the realization that the reservoir that PSC provided is not going to work in an EB without a body lift, so I'm going to have to build my own.
I ordered the AN fittings and steel bungs I would need to make my own tank as well as a vented cap to fill my reservoir with. My plans are to cut two 6x6 pieces of steel the same length, cut one wall of both pieces, weld them together and run a baffle down the middle so the fluid has to flow the entire length of the reservoir twice before it goes back into the pump. That way I shouldn't have turbulent fluid sloshing around and getting foamy, and it will also aid in cooling as the more surface area the fluid passes the more chances it has to cool.
I'm running a small plate and bar cooler from PSC, but it isn't enough for this application - things sure do get hot under the hood of an EB, only going to get worse with a bigger motor. I ended up ordering a killer Derale 16 pass bar and plate cooler that has a nice shrouded fan paired with an automatic fan controller. The fan controller pops on when it reaches a certain temp - I got the radiator probe version as I'm running -6 AN lines as they didn't have one in that side. I'm going to run the probe between the pair of coolers to pop the fan - should help cool things down nicely ;D
I'll post up my reservoir design and costs when I get started on that - I'm going to place the reservoir directly on top of the fender well so the 5/8's hose that feeds the pump is shorter then 6" and it hopefully going to end up ~1.5" above the pump. There isn't much room to work with - it is going to be close...
