I run a 3 core 5.0 Aluminum radiator that is brand new with shroud and flex a lite 16 inch steel fan (the black one with the short fixed blades) pretty much stock 5.0, stock water pump, coated headers but I run a carb instead of EFI.
Timing is set, carb is tuned and it still idles at least 210 and climbing with the AC on. I have right at 3" of space from the front of my water pump pulley to the radiator. When I installed my fan, I used a 1/2" spacer that puts my fan less than 3/4" from my radiator.
I have not found a small pusher to mount in front because my hood latch. Any help would be appreciated.
