bobtail
hi i have a 69 with electrical issues. here is what i have going on. with the ignition switch off i get 12 volts at the hazard flasher. turn on the hazard switch and power is lost. then when i add turning on the blinker left or right both l & r indicator lights blink the voltage at the hazard flasher fluctuates between 4v and 8v. only the turn signal flasher clicks. maybe 8v is not enough to make the hazard flasher click. why do i loose power when i turn on the hazard switch.i have replaced the turn signal switch, hazard switch, ignition switch.
