eds66bronco
after more than a year of replacing the tired old 6 banger/3 speed with a efi 5.0, np435, hydroboost, rear bcb caddy disk swap on a bb rear, disk brake dana 44 front w/ ps. the old girl finally moved under her own power once again!
after bleeding the power steering, i moved on to the testing the hydro boost. all i can say is, i'm glad the bronco was moving slow, as it stopped so fast, i almost went through the glass.
as i sat there testing the brakes, i noticed that if i applied more pedal, it felt like the pedal would sometimes begin to push back up on my foot. as it did this and i held my foot down, it would begin to bog the motor down. if i really stabbed it when it does this, i can actually stall the engine while at idle. it doesn't always do it. i also notice a very slow return on the pedal and if i don't pull the pedal back up with my toe, i still have brake pressure.
rod is not binding, -amost feels like i need a return spring on the pedal.
any ideas? things to check?
